Question about Apple Ipad I-pad
I can be on the same level as my wireless wifi but i lose the signal not all the time what is wrong?
I can get my wireless unit today tomorrow another story some say put it in air plane mode others say turn off air plane mode what should I do ?
  • 53 Answers
Putting airplane mode on/off doesn't matter for the wifi.. it only affect on gsm signals.
Might be your router's signal broadcaster antenna is damaged or not working.
Or try to clean antenna with the alcohol liquid.
Posted on Feb 15, 2014
Why does it keep loosing Wi-Fi connection?
I
is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - The symptoms are a wireless connection that literally will drop out .... the 5th router is wireless CPE AP, wifi signal keep droppings all the time I ...
WiFi problems! Keep losing connection! - Tom's Hardware
www.tomshardware.com/.../wifi-problems-losing-...
Tom's Hardware Guide
Nov 15, 2015 - 9 posts - ‎5 authors
Ok so for some reason ever since we got a new modem and router my HP laptop willhave a full connection and all of a sudden ill lose it and my wifi says "No Networks available" and a red X appears by my bars at the bottom. ... I dont know if maybe my network adapter is going bad or ...
A fix for my Windows 8
Jan 04, 2016 | Tablets & eReaders
Why does my m55 loses wifi connection?
Your other devices all buffer the signals internally. Your TV does not. Any disruptions in the continuity of the wireless signal show up as pauses and breaks in the streaming.
You can spend time trying to diagnose, and then changing WiFi channels But quite honestly, if you have neighbours who don't know or care about wireless then any fix you do will be undone because they'll just trample over your signal again.
Either go with a bit of cable (Ethernet cable) from the router to the TV, or buy some Ethernet of Power adapters (Homeplugs) and use them. Beware though, homeplugs radiate quite a bit of energy because they use the unshielded mains cable for transmission. They aren't as quick either as Ethernet cable direct because of the lag from the encryption/decryption and error correct processing.
Sep 06, 2014 | Vizio M551d-A2R 55" 3D LED Smart HDTV
Google support
Make sure device is fully charged. Try connecting to an open wifi access point (without password) to eliminate possibility of using the wrong password for a secure connection.
Sep 02, 2014 | Google Nexus 7
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Sony vaio loses wifi handshake
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 24, 2013 | Sony Computers & Internet
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Im just trying to get wifi and interet but i cant get a access point in range wat do i do
Hi :)
In order to obtain wireless internet you need the following
1) Wireless Access Point.
2) A device capable of getting these signals
this is a common mistake when you first obtain wifi. Although the signal is wireless it still has to come from somewhere. Wifi is generally a short range system (I say generally because there is that new "Internet Stick" thing that Rogers? is renting and it is the same wifi you would have @ home but its distributed accross thier towers so you have internet most of the time from anywhere). You still need ot go and get Internet Service into your home, then distribute that signal wirelessly accross the house (in reallity its more than the house the point is the signal is being distributed from somewhere nearby) VIA Wireless Router. Even if you could find an Access Point 90% chances that the system is locked and needs a pw so that people cant just steal another persons signal and bog them down and pay for their internet basically.
Now. If that option isnt suitable for now you can obtain Free Wifi Signal from a number of places
1) Free WiFi is offered @ most public/government buildings (ie Library, Courthouse, Registries, etc etc)
2) Appartment buildings and Condoes are always a good place to check for an unprotected network to piggy back off (this isnt as shady as it sounds if its temporary, infact WiFi systems have backups in them that auto detect and connect to unprotected networks should yours lose signal for any reason)
Note Wi Fi systems signal strength and speed are affected by a couple factors
1) The strength of the incoming internet signal (signal is reduced the longer it flows in the lines to get to you or your pc) (IE long cords between wall and modem or device etc etc etc) Signal strength is also dependant on what you purchase/pay monthly of course (IE DSL Dial Up Or Cable)
2) the quality (usually depends on the price of the unit) of the Router you purchase and its ability to distribute that signal at distance
3) The Wireless Adaptor the device has and its range (depends on price and quality of that unit)
4) Distance from the router is a given but from what ive learned Copper Piping and Copper wires in houses / condos/ apartments tend to block signal strength.
GL Comment if you need anything and please rate this answers effectiveness
Apr 09, 2009 | Nintendo DSi Black Console
Boost PCMCIA Wifi Card Range
em maybe you just need to change the pc card or honestly just change the pc for fast and efficient browsing.
Jan 21, 2009 | Encore IEEE 802.11b WiFi Wireless LAN...
Loose connection with router
There must be something that has been introduced to your area that is causing distortion in your WiFi signal. 802.11 or WiFi is very susceptible to noise or signal distortion and can come from many things from interfering objects to other wireless signals such as Wireless phones. There are also many other things that can cause signal distortion I would look to see if you have added anything new around the time the unit lost signal. If your unit is working properly when you are closer to the router than this has to be the problem. Range is a big iffy factor when messing with WiFi.
Feb 26, 2008 | Linksys Wireless-G Range Expander (WRE54G)
Wi fi
You need to determine whether it's your router thats the problem, either overheating or signal lose because of where it's situated, or whether it's your wireless network card losing connection because of a faulty driver programme or the wireless hardware being faulty itself. If you are using the software that came with the wifi card, then try using windows zero wireless configuration instead.
Sep 10, 2007 | HP Pavilion dv8000z Notebook
Apple Ipad I-pad Logo
37 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
