Question about Samsung Televison & Video
Samsung 75 in TV dish with red line through it on left of screen
  • 178 Answers
SOURCE: red vertical line on left side of screen
The diagnostic is very important, If it looks very thin like someone took a magic marker and drew a line down the screen your panel is failing, this is also true if it looks like several small lines running down the screen slightly separated. Now if it is fat and solid across like about an 1/2 inch across or larger and video can be seen behind it, This is another problem usually with a part called a T-con. In some models the t-con is replicable separately from the panel. If you see a discoloration when the tv is off that would be a delimitation failure and that is also a bad panel.
If your panel is bad it will be un economical to repair unless you have warranty. If it is a t-con this will be much cheaper to repair. Somewhere in the 200.00 range for a service call and part. This is the diagnostic we use in home to determine the direction of the repair. It is constant across different brands of televisions.
If it comes and goes, like you are saying it is thin line like I mentioned above, the problem with the panel is the address wires attached to the panel are coming detached off the panel, unfortunately only the factory can seal these wires back onto the panel. There is no method for a shop or homeowner to do this. They use a very high-tech method to seal these wires on the panel. We as a shop have been looking into trying to seal them back but so far we are still searching for a reliable method. There are many hundreds of wires packed in very close together and almost impossible to line up.
The factory does not repair the panel just replace, although they want the old panel back.
Posted on Oct 13, 2009
  • 28 Answers
SOURCE: Our Samsung tv has a reddish, ghostish background
by calling the people that you bought it from and tell them your problem
Posted on Nov 07, 2009
SOURCE: have red blue vertical lines on samsung lcd tv
Oh ok
Posted on Feb 09, 2010
  • 16174 Answers
SOURCE: samsung 75 smart tv , is power on or off when red light is on ????
Red light means that the unit is in standby mode, It has power but is not turned on.
Posted on Jul 24, 2015
  • 491 Answers
SOURCE: a samsung tv ps43f4000ac with vertical lines running vertical on left side also no audio but video ok
Take it to a TV repairer as there is nothing you can do yourself.
Posted on Jun 21, 2016
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
I have vertical red lines on my samsung LCD flatscreen tv after remounting on the wall. There is no picture, no sound, just red lines. Any help to repair?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 25, 2015 | Samsung LN40A550 LCD TV
Samsung 75 smart tv , is power on or off when red light is on ????
Jul 24, 2015 | Samsung New 75"" Class 74.54"" Diag. LED...
I have black lines in my samsung 75 inch tv model un75f6400
This could be a problem with the cable.See if the connections on both sides are tight.
Jul 28, 2014 | Samsung Televison & Video
Red lines on Samsung UN46B7100. Is this the TCON board or the panel?
Have you checked all cables first? Color fluctuations and problems of this nature can be caused by a bad VGA/HDMI/Component cable. Try plugging your source device into other inputs and see if you get the same result. If that happens you more than likely have a bad video card.
Aug 31, 2012 | Samsung UN46B7100 45.9 in. LCD TV
Screen Repair
Try searching SAMSUNG TV through Google search. You will find the servce center to your nearest location.
Apr 22, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I have a 42" Samsung Plasma. We have had it two years so the warranty just ran out. We have a half inch red line down the left side of the screen. Also, when the screen should be black, there are hints of...
ONE OF TWO THINGS, THE LINE COULD POSSIBLY BE FIXED WITH A SCAN BOARD, BUT NOT LIKELY, PROBABLY NEEDS A SCREEN REPLACED, THE OTHER RED STUFF CAN BE FIXED WITH A X-BOARD REPLACEMENT, BETTER OFF TO BUY A NEW TV
Dec 30, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Red thin line on left side of screen / black colours have a burnt red tinge over them. TV is 30 months old
If that line is permanently on the screen  - even when you are using the AV signal then the LCD panel is busted, no way to repair it. Try getting it replaced under warranty, it shouldn't have failed so soon
Oct 30, 2009 | Samsung LA32A450 32 in. HD-Ready LCD TV
Televison & Video Logo
14 people viewed this question
Henry  Thomas
Henry Thomas
