Question about Clymer Shop Manual - 95-98 Polaris 425 Magnum 4x4
No spark had spark when it was turned off, now I have nothing. I'm not sure if I have the wiring correct because I don't have a diagram for it. One more thing, could you tell me how to test the coil?
    Scholar:
    New Friend:
  • 104 Answers
You can have the coil tested at your local auto parts store. Call first, but do not try checking it yourself, it could kill you.
Check your local auto parts stores to see if they have a Repair Manual. If they do not, then I would call your local Libraries to see if they have one that you can check out.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Posted on Feb 15, 2014
1965 chevy pickup/283 motor,spark plug wiring diagram
look on the intake most of the old cars had them stamped or raised numbers on them. then you just have to figure out tdc for 1 and match up the cap to number 1 and figure out which way the motor turns to know for sure your installing the wires correctly.
Mar 12, 2015 | Chevrolet Cars & Trucks
Correct spark plug wiring diagram
Firing order for a 305 is 1-8-4-3-6-5-7-2. The distributor turns counter clockwise and #1 should be the 5 o'clock position looking down at the top of the distributor.
Jun 29, 2013 | 1986 Pontiac Firebird
94 softail 80cubic inch no spark
Hi Don, you may have a faulty cam timing sensor and alot of the following applies to late models, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 9 volts, loose or broken battery cables especially "GROUND" cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For a prime suspect please visit the website below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
May 16, 2012 | Harley Davidson Motorcycles
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
Not sure how to replce spark plug wires from the distributor need help please send info
change one spark wire at a time on the distributor.buy new set of spark plugs wires remove them from box.match old wires with new wires to use the correct length to each cylinder.now if you need to change distributor cap.mark location distributor cap.number tag plug wires on the distributor cap so you can remove plug wires on distributor cap so you can replace cap and rotor and put wires back on the distributor cap in correct place.remember change one plug wire at a time so you wont get confuse.
Apr 15, 2011 | 1992 Ford Tempo
Vacuum lines diagram 351m
Click over diagram for zoom...
Fig. 6: Vacuum schematic - 351M engine
Fig. 7: Vacuum schematic - 351M engine
Hope this helps (remember to rate and comment this answer).
Apr 12, 2011 | 1981 Ford F 150
Put new battery in a month ago, now when i turn key on nothing happens, no dash indicator lights come and nothing happens when key is turned on
Possible errors are either incomplete or non-load generator ground connections between the engine and car body.
Mar 04, 2011 | 2003 Chevrolet Silverado 2500HD
My 1999has. Always. Work. Good. Kept. Up. With. The. Maintenance but. From. One day to another. My Tahoe. Started. Idling. Rough. So put. Some. Gas treatment did it. Twice. Nothing. Happened. So i spark....
I had thi same problem with my Silverado....you have one of two problems....bad computer or a bad fuel pump. Check with the salvage yard for a used computer (located unde the glove compartment). Good luck
Feb 11, 2011 | 1999 Chevrolet Tahoe
No spark
Make sure you are getting spark from the coil. Then connect the coil wire to the distributor. Then check a plug wire for spark by grounding it with a screw driver. If you are getting spark from the coil, but not from the distributor wire there could be a wire broke in the distributor.
Aug 06, 2008 | Electrical Supplies
Clymer Shop Manual - 95-98 Polaris 425 Magnum 4x4 Logo
544 people viewed this question
Top Clymer Home Experts
Donni Steen
Tom Chichester
Are you a Clymer Home Expert? Answer questions, earn points and help others
