Question about Ovens
Kitchen aid mod ykerc607hw7 range elecrical diaggrame
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: it takes so long for my Kitchen Aid slide in range
Could be a faulty element or faulty thermostat. Both will need to be tested to see which is problematic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 31, 2009
How do I replace oven temperature fuse on a Kitchenaid Superba gas oven Mod.#KGST307HBS6?
have looked at the schematics can't find a fuse anywhere
see all parts here...
Kitchen aid made by whirlpool.. http://www.appliancepartspros.com/parts-for-whirlpool-kgst307hbs6.html
bad temp sensor maybe?
Feb 07, 2018 | KitchenAid Ovens
My kitchen aid YKERC607 oven, bake, broil does not work. oven top works however
If it is an electric range, it would be a control issue. If it is Gas, it could be ignitor or safety valve.
Mar 15, 2015 | Ovens Ovens
Kitchen aid oven /range model # kgrt607hbl4
The "window" is comprised of two sheets of glass enclosed by a metal band. Heat expansion results in a less than perfect seal and admission of material thrown off by cooking. It is not practical to attempt cleaning it.
Jun 25, 2014 | KitchenAid Ovens
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
Remove oven door on kitchen aid gas stove for cleaning
Usually the doors just lift off.
Keep your fingers away from the hinge region as they can release and whack your fingers
Jan 03, 2011 | Ovens
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
It takes so long for my Kitchen Aid slide in range to preheat
Dec 31, 2009 | KitchenAid Ovens
Will not come on after self cleaning
this is a common occurance with many self clean ranges, especially slide in and wall oven units. the kitchen aid ranges usually have a non reset hi-limit. meaning it opens one time and needs to be replaced, sadly.
to replace the thermostat can be tricky to do if you're not experienced, so if you have any reservations about taking you range apart, call a qualified tech in your area. if you decide to take a go at it, well first things first.
**FIRST unplug from the wall or shut off the breaker**
*the other issue is not knowing what model you have.
I can tell you most recent kitchen aid units made by whirlpool have a fixed hi-limit at the back outer oven wall. remove the rear panel, and the hi-limit should be easily accessed. that part # 8300802
hope that helps,
good luck
Sep 28, 2009 | KitchenAid Ovens
Ovens Logo
166 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
