Question about Horizon Fitness T303 Treadmill
I just assembled my Horizon T303 treadmill and when I plugged it in and turned it on, the display on the console read "Connect" and nothing else worked. What am I missing or what needs to be connected?
  • 12 Answers
SOURCE: lost lubing instructions for treadmill and tool ex wife took them
Horizon fitness sells silcone gel lubricant or many stores also carry it.
Gerritt
Serving the Twin Cities
Posted on Mar 13, 2009
valiantma595
  • 176 Answers
SOURCE: I have a T54HR horizon treadmill. The problem is
best if you see the local retailer where you bought the treadmill. Obviously the switch, whick is a magnetic disc is not activating the sensor in the control panel and need to be looked at.
Posted on Sep 23, 2009
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
ercupa190
  • 12223 Answers
SOURCE: My horizon t901 treadmill console display has stopped working any ideas ?
please adjust the REED switch, see the diagram attached, clean it+tight the connector very well, and test for open or faulty with DVOM
2) tight the ribbon cable for keypads
3) replace the batteries by new ones. and clean the contacs batteries very well.see the block diagram
Posted on Feb 18, 2013
ercupa190
  • 12223 Answers
SOURCE: horizon t202 treadmill makes a constant beeping
1) adjust the REED switch see the diagram attached. Clean it+ 2)test for open or faulty 3) tight the connector very well.
2) tight the upper and lower connectors very well and clean it.
3) inside from console tight the ribbon cable and clean it
Posted on Sep 02, 2013
Testimonial: "Thank you Mr. Ernesto Cuadra, I can't wait to try this tip out."
Horizon Treadmill Ct5.1 turns on, displays nothing and beeps nonstop
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 26, 2016 | Horizon Exercise & Fitness
Hi I have a horizon t4000 premier treadmill, everything seems to work fine when I plug it in, it all the console displays fine, but p1 (programme 1) just keeps flashing and no response from any of the
Hi Anthony, sounds like there is a bad connection from upper to lower, a pinched or bad cable, or bad solder on a connection point.
With the "flickering" of the console lights mentioned, this tells me that the power supply connections to the console were suspect at one time, and doing nothing and having it "work ok now" is not a good sign of something being fixed. Also, with the flickering, this would mean the upper board would be intermittently powering up / down, causing massive trouble with the onboard CPU which is trying to operate the system. I would advise against using the unit the way it is, and have the control board checked. You can contact jatinah electronics for further help if needed. Good Luck!
Jan 11, 2015 | Horizon T4000 Premier Folding Treadmill
Horizon Treadmill won't run?
Check this attached link for trouble shooting information
May 31, 2014 | Horizon Fitness T101 Treadmill
How can i change console readouts on horizon T4000 premier from miles to kilometrs?
there are 2 ways: 1) under the display board there are small orifice, make click with a eraser point pencil.
2) go to the MENu, and sellect to change miles to kms. read you owner manual or download free: www.fitness.manualsonline.com
God bless you
Oct 19, 2013 | Horizon Exercise & Fitness
Horizon t207
follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 08, 2013 | Horizon Exercise & Fitness
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
The console display on my Horizon Fitness T63 treadmill won't stop scrolling/flashing the programs (P1-P6) and will not start up.
Sounds like there is a stuck button on the console, or possibly a loose ribbon cable inside the upper console maybe?
Oct 21, 2010 | Horizon Fitness T90 Treadmill
How do I calibrate my horizon t102. I turn it on and the level motor continues to run, the treadmill motor wont come on. I think it is a level sensor that is bad. Where is that located
The "level sensor" is built into the elevation motor assembly, which is a 10kohm potentiometer. What year treadmill? If the elevation motor assy has a small connector with an orange, blue and brown wire set, you can use an ohm meter to read this pot on these leads. It sounds like a loose cable upper to lower, or possibly a faulty motor control bd which controls the elevation. Unplug tread before looking around..
Oct 20, 2010 | Horizon Fitness Horizon T102 Treadmill ...
Horizon Fitness T303 Treadmill Logo
47 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
