Whirlpool wfs 1273 error F12 - Washing Machines
2 Suggested Answers
TerryTown
  • 292 Answers
SOURCE: wfs 1273 bw n 387
http://www.manualsonline.com/
http://laundry.manualsonline.com/ex/product/headline/m/whirlpool/d/Washing%2BMachine/p/WFS1273BW
Here is a couple of locations that have the requested manuals.
Best wishes,
TF
Posted on Jun 03, 2011
I have a whirlpool wwdc7410 (sixth Sence) washing machine that is showing a F12 error, can it be fixed easily?
F12 is a problem with the heating element if you not sure on have to check it, u migth want call a appliance tech to fix it ok
Mar 30, 2018 | Whirlpool Washing Machines
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
Code 1273
Four digit codes are model specific. Code 1273 for Nissan products is for a problem with the O2 sensor - bank one sensor one.
That sensor is before the catalytic converter on the side with cylinder one. The sensor and circuit to the computer would need to be tested.
May 03, 2013 | 2005 Nissan Quest
Whirlpool washing machine WFS1273AW manual
I have a whirlpool WFS 1273 AW front loader that gets stuck in the spin cycle. The timer counts down from 18 minutes to 17 minutes and starts to spin but before it gets to full speed the control panel lights all flash, go blank, and the. The timer resets to 18 minutes. I have cleaned he drain pump, removed the clothes and tried it when empty and it does the same thing. It does not appear out of balance.
Jan 04, 2012 | Whirlpool Washing Machines
F 12 error
The F12 error does not appear on all washers. On a Hotpoint (you didn't state which washer you had), F12 indicates "No mixed fill - Check water supply". Check water at the taps as well as the hoses to ensure a constant water supply.
Nov 16, 2011 | Whirlpool Washing Machines
Whirlpool washing machine WFS 1273 BW keeps coming up with "clean pump" light.Even after i have cleaned pump.Now when I switch machine on sounds like pump is running but no water is coming in and...
Hi.
If you have already cleaned the drain filter in front you may have siphoning. Siphoning means that water is flowing back from the drain hose because of incorrect hose settings. Make sure that the hose is set as from installation manual.
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/ifu/home
Also make sure that you have checked well the drain filter, the one behind the trim at the base in front of the appliance.
Check the drain hose. When there is no blockage at the filter that is usually the cause. If drain hose is not responsible, then parts must be tested. Pump, pressure sensor orcentral control module may be faulty, but that does not happen very ofter.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Oct 05, 2011 | Motorcycles
F12 code
Ive looked thru all my manuals and can not find a f12 error code anywhere even looked on-line all you can do is call Whirlpool in the morning and speaking with there customer service reps to find out what it is sorry for the troubles....
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code f12
Hi, F12 means a communication error .Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wiring Harness connections to the MCU, the motor, and the Central Control Unit (CCU)
• Check the Drive system
• Check MCU
• Check CCU
• Check Motor
Replace failed part
Take care
May 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Canon i9950 printer problem error 5c00
According to the Service Manual Error Code List these are the two possible candidates to cause this failure:
- Purge unit (Part-No. QM2-1307)
- Logic board ***’y (Part-No. QM2-1272/QM2-1273)
which means, this device has to go to the service.
(Or to bereplaced)
Best Regards
cominarosa
Mar 04, 2010 | Office Equipment & Supplies
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
