Fisher & Pykall GW711 Excellence top loader washing machine error code 49. what does that mean & how do i fix?
Error code 49 what does that mean?
4 Suggested Answers
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
BIKER T
  • 909 Answers
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Posted on Sep 14, 2009
Fisher & Paykel WL26CW1 - Error Code 49! can i swap the hot and cold valves to make it work and disconect the hot valve?? and love this site very informative, Thanx Guys..
The most common problem with AquaSmart is the pump
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Mar 19, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Fisher & Paykel gw711 excellence keeps filling and overflowing
the clear pressure tube is blocked,
you need to blow air down the clear pressure tube hose.
Jan 30, 2013 | Fisher and Paykel GWL11 Top Load Washer
Error code 49 on fisher and paykel 8kg aqua smart washing machine, model number: wl80t65cw1. What does this mean?
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
May 15, 2011 | Fisher and Paykel Washing Machines
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
May 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
How do i clean out the filter for my GW711 excellence top loader washing machine? everything keeps coming out completely covered in lindt and undissolved washing powder. I cant seem to find out how to...
It doesnt have one, try the following- use high quality detergent- like tide. Do a full wash with nothing in it every now and then, separate lights and darks and towels/fluffy stuff from synthetics, use a less rigorous wash- like wool or permanent press. If none of that works, ring up the manufacturer and complain
Apr 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
