Question about Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module
Make a module or find a way to bypass pat system
2 Suggested Answers
SOURCE: Bypass Computer PATS
in search of my own PATS related issue, i've seen quite a few documents with relative info. from what i've been able to gather from these, the EEC and PCM must be replaced together ('98 and newer) as they are coded to each other as well as a key coded to them. to do this, assuming you did get both replaced as new units and not pulled from junkers, you must also aquire a ignition cylinder equipped for reading a PATS key (might as well be a 2000). this is all speculation, but i believe you could mount the new cylinder somewhere in the dash, perhaps behind the glove box, many models have extra room back there. then run the PATS related wiring to the new cylinder, and tow it off to a dealer. coding the key in that year model computer requires the proprietary ford scanning tool and about half an hour minimum. once coded, you can leave the key installed in the dash and use your old one to start the truck as normal. if you were unfortunate enough to get your PCM from a junker, be prepared to pay quite a bit, since you'll need yet another PCM and EEC. i've seen many a forum post with claims of $1200 bills for replacement and coding of a key. i dont believe your instrument cluster will be 100% compatible either but theres something to hope for.
Posted on Jul 28, 2009
How do I bypass / remove the anti theft system
They make a module to bypass the PATS system. It is needed to install after market remote start but it should work on your Ranger. Here is a link to Amazon webpage.
Amazon com Directed Electronics 555P Ford Pats Bypass Module Automotive
May 26, 2016 | 2000 Ford Ranger SuperCab
How can I bypass the pats system on a 1999 crown victoria
Ford P.A.T.S system bypass - YouTube
? 2:05
www.youtube.com/watch?v=CvRKZ-DHjGk
Mar 13, 2013 - Uploaded by Ryan Dubyak
Ford P.A.T.S system bypass. Ryan Dubyak ... Transponder Chip Key Bypass How To For Any Car! - Duration ...
Bypassing the PATS ' 4.6L Based Powertrains ' Crownvic.net
www.crownvic.net > ... > 4.6L Based Powertrains
Jun 27, 2011 - 15 posts
They have an entirely different PATS system that does not have an .... I've had a '99CVPI PCM in my '98 MGM for about 10 months now, even ... For ANY of you 1998-2000 Grand Marquis or non-police Crown Victoria guys, ...
Oct 31, 2015 | Cars & Trucks
Is there a way to bypass the PATS systm on a 2014 ford mustang?
The PATS system is integrated into the Engine Control Module on Ford vehicles ,so I doubt there is an effective way to bypass it.
Feb 25, 2015 | Ford Cars & Trucks
P1260
P1260 indicates that the Passive Anti Theft system (PATS) detected a "theft condition". This basically means an incorrect signal, or no signal at all was received from the chipped key. Brief overview: your ignition key has a chip in it called a transponder that is read by the PATS transceiver (mounted around the ignition cylinder housing behind the column shroud). The signal is then sent to the PATS control module, which communicates with the Powertrain Control Module (PCM) and enables the vehicle to start. Sorry for all the acronyms! When an incorrect signal is received, the PATS module then sends this message to the PCM which triggers the P1260 trouble code, resulting in a no start condition. Possible causes are: an incorrect key being used, faulty key chip (transponder), wiring concerns between the transceiver module and PATS module, the transceiver module itself or internal PATS or PCM module concerns. The first thing to do in this instance is retrieve codes from the PATS module and diagnose these. Once the PATS issues have been resolved you can reset the P1260. Communication with the PATS module will likely need to be done at a Ford dealer. A few things to check first: make sure the correct key is being used, and if you have a second key, try that one as well. If one key starts it but not the other, you may have a faulty key. If both keys do not work, then it is not likely a key problem. Honestly, we see very few problems with the keys themselves. Make sure no one has tampered with the steering column shroud as the transceiver module located behind it is fairly fragile. Lastly check for an aftermarket remote start system. These are a common cause of no start problems with PATS equipped vehicles. Some installers will remove the chip from your key and tape it to the column (under the shroud). This basically bypasses the system and allows it to be started without a chipped key. The problem is that the transponder removed from the key is not designed to be used in this way and can fail due to extreme temperature changes and, depending on mounting condition, excessive vibration and shock. Other installers use a "key box" installed under the dash, and these have been known to cause issues as well. If you suspect the concern to be related to a remote start it may not be a bad idea to have it checked or removed to complete diagnosis
May 17, 2011 | Ford Explorer Cars & Trucks
Im instaling a remote start alarm on my 1999 ford f 150 how do i bipass the anti theft and i do not want to carry 2 remotes around
The 2 Key fob part, is to get a remote start that also has the RKE ( Remote Keyless Entry ) function. The the RMST / RKE system is installed, the RMST fob would be able to operate the door locks ( you can put the factory RKE fobs in the drawer )
the PATS ( Passive AntiTheft System ) part is to get a PATS bypass module for the remote start. The remote start that you purchase needs to be able to activate this prior to starting the truck ( usually pulse / signal outputs, most mfgr of RMST have these ).
There are a few PATS bypass modules, I have only used the Ford branded one ( which I think is also made by CodeAlarm, not 100% sure ).
Jan 16, 2011 | 1999 Ford F150 Regular Cab
Can you please help, Code P1260, Theft detected Eng Disabled.
Honestly, we see very few problems with the keys themselves. Make sure no one has tampered with the steering column shroud as the transceiver module located behind it is fairly fragile. Lastly check for an aftermarket remote start system. These are a common cause of no start problems with PATS equipped vehicles. Some installers will remove the chip from your key and tape it to the column (under the shroud). This basically bypasses the system and allows it to be started without a chipped key. The problem is that the transponder removed from the key is not designed to be used in this way and can fail due to extreme temperature changes and, depending on mounting condition, excessive vibration and shock. Other installers use a "key box" installed under the dash, and these have been known to cause issues as well. If you suspect the concern to be related to a remote start it may not be a bad idea to have it checked or removed to complete diagnosis.
I hope this information has been helpful (remember to rate this).
Oct 12, 2010 | 1996 Ford Explorer
P1260 , on 2001 ford f150, with a 4.6
P1260 = Theft Detected - Engine Disabled
This OBD Code indicates that the Passive Anti Theft system (PATS) detected a "theft condition". This basically means an incorrect signal, or no signal at all was received from the chipped key. Brief overview: your ignition key has a chip in it called a transponder that is read by the PATS transceiver (mounted around the ignition cylinder housing behind the column shroud). The signal is then sent to the PATS control module, which communicates with the Powertrain Control Module (PCM) and enables the vehicle to start.
Communication with the PATS module will likely need to be done at a Ford dealer. A few things to check first: make sure the correct key is being used, and if you have a second key, try that one as well. If one key starts it but not the other, you may have a faulty key. If both keys do not work, then it is not likely a key problem. Honestly, we see very few problems with the keys themselves. Make sure no one has tampered with the steering column shroud as the transceiver module located behind it is fairly fragile. Lastly check for an aftermarket remote start system. These are a common cause of no start problems with PATS equipped vehicles. Some installers will remove the chip from your key and tape it to the column (under the shroud). This basically bypasses the system and allows it to be started without a chipped key. The problem is that the transponder removed from the key is not designed to be used in this way and can fail due to extreme temperature changes and, depending on mounting condition, excessive vibration and shock. Other installers use a "key box" installed under the dash, and these have been known to cause issues as well. If you suspect the concern to be related to a remote start it may not be a bad idea to have it checked or removed to complete diagnosis.
Also, its possible that you are interesting in check the Ford F-150 - Owners Manual (page 94)
I hope this information has been helpful (remember comment and rated it)
May 28, 2010 | 2001 Ford F150 Styleside SuperCrew
Is there a kill switch for an alarm on a 1998 mountaineer that will help the car start
The passive anti-theft system (PATS) contains the following components:
  • theft indicator
  • encoded ignition key
  • transceiver module
  • PATS control module (located behind the passenger side air bag module)
  • powertrain control module (PCM)
  • standard corporate protocol (SCP) communication network
The passive anti-theft system (PATS) uses radio frequency identification technology to deter a driveaway theft. Passive means that it does not require any activity from the user. This system is known as SecuriLock® in North America, Safeguard® in the U.K., and PATS in continental Europe. This information can be found in customer literature such as the Owners Guide.
The PATS uses a specially-encoded ignition key. Each encoded ignition key contains a permanently installed electronic device called a transponder. Each transponder contains a unique electronic identification code out of over 72 million billion combinations.
Each encoded ignition key must be programmed into a vehicle's PATS module before it can be used to start the engine. There are special diagnostic repair procedures outlined in this manual that must be performed if the encoded ignition keys need to be replaced.
The encoded key is larger than a traditional ignition key. The key does not require batteries and should last the life of the vehicle.
The transceiver module communicates with the encoded ignition key. This module is located behind the steering column shroud, and contains an antenna connected to a small electronics module. During each vehicle start sequence, the transceiver module reads the encoded ignition key identification code and sends the data to the PATS module.
The control functions are contained in the PATS module. This module performs all of the PATS functions such as receiving the identification code from the encoded ignition key and controlling engine enable. The PATS module initiates the key interrogation sequence when the vehicle ignition switch is turned to RUN or START.
PATS uses the p owertrain control module (PCM) to enable or disable the engine. The PATS module communicates with the PCM over the SCP communication network in order to enable engine operation. The PATS module and the PCM use sophisticated messages in order to prevent a theft. The PATS and the PCM share security data when first installed together, making them a matched pair. After this security data sharing, these modules will not function in other vehicles. The PCM shared security ID is remembered even if the battery is disconnected. The PATS module also stores the vehicle's key identification code, even if the battery is disconnected. There are special diagnostic repair procedures outlined in this workshop manual that may be carried out if either the PATS module or the PCM needs replacement.
All the elements of PATS must be functional before the engine is allowed to start. If any of the components are not working correctly, the vehicle will not start.
PATS uses a visual theft indicator. This indicator will prove out for three seconds when the ignition switch is turned to RUN or START under normal operation. If there is a PATS problem, this indicator will either flash rapidly or glow steadily when the ignition switch is turned to RUN or START. PATS also "blips" the theft indicator every two seconds at ignition OFF to act as a visual theft deterrent.
PATS differs from the perimeter anti-theft system in that PATS enables and disables the engine from starting. If equipped, the perimeter anti-theft system protects the perimeter of the vehicle (doors, hood and trunk) and sounds an alarm.
The PATS is not compatible with aftermarket remote start systems, which allow the vehicle to be started from outside the vehicle. These systems may reduce the vehicle security level, and also may cause no-start issues. Remote start systems must be removed before investigation of PATS-related No Start issues.
The passive vehicle protection system will be activated and will disable the vehicle from starting if there is a:
  • damaged encoded key.
  • unprogrammed key.
  • non-encoded key (key has no electronics).
  • wiring concern.
  • transceiver concern.
  • PCM concern.
  • module communications network concern.
Mar 10, 2010 | 1998 Mercury Mountaineer
1100F DEI bypass module on a 2003 sport trac
if nothing else just use the "key in the box" method for bypassing the explorer, only thing is you will loose a key, good luck
Nov 23, 2009 | Directed Electronics 1100f Ford Pats...
Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module Logo
24 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Mark Skinner
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
