Question about Express Mens SelfWinding Skeleton Bracelet Watch Black Pitch Black, No Size
I'm not sure about this arm movement.
This watch is "automatic," self-winding," and "powered by arm movement." I set the watch and am now just waiting for it to start. I set the time it told me to: pull the crown, set the time, and push it back. Nothing is happening.
  • Express Master
  • 18,424 Answers
If the watch as not been worn for a long time it's best to wind it by hand first to get it started, just make sure the winder is pushed all the way in and then just keep winding it clockwise till it start going..
Posted on Feb 15, 2014
I have a folio 21 jewels limited addition watch. I dont know how to wiend it. And I need to know what its worth.
I have no idea of the value.
You say that it's self-winding, but that you don't know how to wind it? Just wear it - the movement of the arm and wrist winds the watch. If the watch is fully wound down then it may take a while for the watch to have enough power to restart. Some automatics will allow you to wind the watch in the normal way with the crown.
Oct 21, 2017 | Black Watches
Do new James Michael pocket watches come with a battery?
Yes, if it is of the battery type
Movement Type
The movement, or inner workings, of a watch are what make up the main timekeeping mechanism. This mechanism measures the passage of time and displays the current time and other information including date, day and month. These movements can be entirely mechanical, entirely electronic or a combination of the two.
Mechanical movements, such as hand wound or automatic watches require winding in order to run. An automatic watch uses the force of gravity to constantly wind itself. Automatic watches have a greater consistency of power and therefore can be more accurate.
An electronic watch employs the use of a tiny quartz crystal that vibrates in the presence of electricity. This type of watch is powered by a battery and their time is regulated by the tiny quartz crystal. This is why most electronic watches are also called quartz watches. Solar powered watches convert energy from light into electricity which is then stored in a rechargeable battery. These watches do not need to have the battery replaced as long as they are regularly exposed to a fairly strong light source.
Kinetic powered watches use a combination of mechanical and electronic elements. Usually a weight rotates with the motion of the wearer?s arm which turns a generator to supply power. It is similar to an automatic watch except that electrical power is generated by the mechanical motion.
Men James Michael Pocket Watch
Jun 19, 2016 | Pocket Watches Watches
I cant get the arms to automatically set themselves
About Self-Winding Automatic Watches - Self-Defense Armory
www.selfdefensearmory.com/aboutautomatics.html
about mechanical watches, self-winding, automatic watches. ... Secondly, and this is where it gets a little hazier, people buy automatics for reasons that cannot be clearly ... Self-winding automatic watches depend on the movement of the arm to ... Avoidsetting the day and/or date (if your watch has these functions) at night.
About watch movements: technical details
Dec 26, 2015 | Casio GA-110-1B GA110 G-Shock Alarm World...
Everytime my self winding runs down, why do I spend hours trying to get started again?
An automatic watch receives it power from the mainspring, which is wound by hand (most watches) and from movement of the arm which causes the Oscillating Weight to spin around and wind the mainspring. The problem is that it takes many, many rotations of the weight to put enough winds on the mainspring to keep it going. If you have not worn the watch for 24 hours you need to put initial winds on the mainspring, either by turning the crown or by swinging the watch around 30-40 times. If the watch is in good mechanical condition, once you put the initial winds on it, you can put it on your wrist and it should run overnight if taken off. Most older Seiko watches cannot be wound by hand.
Nov 24, 2015 | Watches
Relic watche zr11853 automatic is not working. No movement in the skeletal innards but the dial works if pulled out. There shouldn't be a "battery correct?
the RELIC ZR11853 is an automatic movement (spring) you have to rotate the crown to wind the spring,
the Automatic part is, when its worn on the wrist, the movement of your arm swings a small weight in the watch that winds the spring.
May 25, 2013 | Watches
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
Jul 31, 2010 | Bulova Watch
Watch stops shortly after any movement
Automatic, or "self-winding" watches get their power from movement of your wrist throughout the day. Unless you're quite active the amount of movement is just about enough to keep it running till the next day. However, if you let the watch run down completely as you did when you were away, there is no reserve power left. The solution is simple: just manually wind the watch and you'll be good to go. To manually wind the watch unscrew the crown as if you were going to set the watch but do not pull it out as would for setting. Wind the watch about 40-50 turns and it will run fine if you wear it every day.
Apr 10, 2010 | Rolex Mens Airking Watch
My watch is not moving . I want to know do I need to change the battery or it is self wind? ref. 384858.Thanks
Its easy to tell if its battery operated or self wind. Turn the crown (where you set the time) forward. Self wind watches will click as you turn the crown. If its battery operated then you will hear no clicks. Some watches have a screw down crown so if the crown wont turn forward then try turning back. Some watches have a capacitor that needs to be charged! Seiko Kinetics are charged by movement like an older automatic. Citizens are charged by light!
Jan 09, 2010 | Piaget Watches
Red hand for dual timezone
If your watch has mechanical- self winding movement, then ALL the gears, hands and functions are mechanically driven and executed. None of the hands can be winded, as the movement of the hands is the consequence of the releasing power of the winded mainspring. All hands (including dual time zone hand) can be udjusted only to the required time and the rest is done automatically by the gears, cogs and levers.
If the dual time zone hand is not functioning properly- there is some mechanical fault and you will have to get the watchmakers help to sort it out.
Do not forget to rate, please.
Mar 07, 2009 | Breitling Navitimer A2332212 G5 431A watch
Express Mens SelfWinding Skeleton Bracelet Watch Black Pitch Black, No Size Logo
54 people viewed this question
Top Express Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Express Watch Expert? Answer questions, earn points and help others
