Question about Samsung Televison & Video
Red saturation on Samsung tv How can i fix? - Samsung Televison & Video
    Problem Solver:
  • 7 Answers
If you are using component video, make sure your blue is connected. cable may be bad as well.
Posted on Feb 23, 2014
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
Samsung lnt3242h red
check all your input cables & sources.If that doesn't solve the issue you may need to replace MAIN PCB, several part numbers listed at this site (correct part # dependent on your complete model#)
https://www.encompassparts.com/model/SMGLNT3242H/_/_/Samsung/LNT3242H/LCD_TV
also check this site: http://www.shopjimmy.com/catalogsearch/result/index/?q=lnt3242h&tv_brands_select=Samsung&tv_models=Samsung+LNT3242HTX%2FXAA
Again, you will need your complete model# for proper part# & pricing.
Feb 15, 2014 | Samsung LNT3242H Television
How to fix red line though samsung plasma tv
A single red line is a bad panel. The only fix is to replace the panel. Would be more cost effective to replace the TV.
May 06, 2011 | Samsung SPN4235 42 in. Plasma HDTV
I have had this samsung dlp for about 3 and half yrs and i have white dots that have saturated the screen , it started with a few here and there but now its just about in there thousands , if you stand...
The DLP chip needs to be replaced.Samsung will cover the cost of the part and labor if you call 1-800-samsung. This is a very common problem that samsung will fix for you, if you call them.
Jun 17, 2010 | Samsung SP50L3HX 50" DLP TV
Picture is saturated in green with vertical wavy white lines"
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 15, 2010 | Samsung HCM4216W 42" Rear Projection...
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a Symphonic 32" Color TV the picture is red. I need a tv repairman person to come out and look at the TV.
the dives or guns are out of balance. either the blue and green circuits are weak or the red drive is maxed out. when picture tubes are getting old, this normally occurs.
another thought is that the tint is incorrect and saturated. what is the picture quality details?
Sep 21, 2009 | Symphonic ST419E TV
Toshiba 36AF41 36" TV no red color
Go to your menu/settings from the remote (or buttons on the tv, if applicable). And find the color or saturation settings, play around with those. If that doesn't work, your tv is dead, get a new one.
Mar 07, 2009 | Toshiba 36AF41 36" TV
Samsung 52 in. projection TV
Is there any way that you can take a pic of what the screen looks like and post it here or send it to me at slinteriors@yahoo.com I could make a more accurate assesment if you can.
May 03, 2008 | Samsung PCL5415R TV
Durabrand 27" TV
the problem, lies on the flyback ,, on the flyback there two adjustment, the screen and focus that was writtten , adjust only the screen slowly untill screen of your tv back to normal.....fading because over saturation of voltage, adjust the screen trimmer counterclocwise....
Feb 23, 2008 | Durabrand DWT1905 TV
Televison & Video Logo
21 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
