Question about Thermador Kitchen Ranges
Thermador range hood turned itself on and we could not turn it off
2 Suggested Answers
heavyt15
  • 91 Answers
SOURCE: model jxt8136ad6 range hood fan turned itself on,
replace control...on going problem..
Posted on Nov 04, 2009
Thermador cook n vent stuck in the up position. We have a thermador cook n vent. We had it running for about an hour. We turned the fan off but now it is stuck in the up position and will not go down. ...
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
Aug 11, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
Thermador RDSS30 Cooktop works fine. Oven will not turn on. Any button pushed says ''OFF''
My Thermador CT 127 Convection Oven will not turn on. Lights work, convection fan works, oven will not heat.
Jun 06, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Lightbulb Dacor Hood
simply remove filter screen from hood (might as well clean it while it is out), reach your hand through the opening, grasp the light bulb and turn clockwise to remove.
had same problem myself and this is what i did.
Feb 23, 2008 | Thermador 36'' HTSW Series Stainless Steel...
Thermador downdraft does not stop going up and going down automatically
I had a similar issue with the Thermador CVS30R hood continually going up and down, and also issues with the fan starting.
The issue was found to be a loose control arm off the motor. The arm itself moved outward on the motor shaft which resulted in it missing the switches that control the hood up/down and fan start.
This was a somewhat simple fix. Make sure the hood is in the down position. Unplug the unit from power(important!). Unscrew the screw that connects the drive arm to the drive link. Unscrew the motor/control cover, then unscrew the 4 screws holding the complete motor/control unit on (2 Phillips-head screw on each end of the assembly). Pull the complete motor/control assembly out, be careful of wiring. Once out, push the drive arm on firmly onto the motor assembly and tighten the screw. When doing so make sure the 2 micro switch arms are not caught and are free to switch.
When placing the unit back in, ensure all wiring is clear from being caught and ground is reconnected. Put it all back together and done!
I found this link to be useful for a parts/configuration diagram:http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232629&diagram_id=194441#d194441
Jun 05, 2007 | Thermador CVS30R Kitchen Hood
Kitchen Ranges Logo
71 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
