Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
I have no heat coming out - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
If it's blowing out cold air you either need a new thermostat or antifreeze need's to be checked .If it's not blowing at all it could be blower relay, fuse or u need a new blower.
Posted on Feb 17, 2014
Aux heat comes on
If you turn your heat on and the temperature is set 3 degrees above what the actual temperature of the room, the auxillary heat will automatically come on. The auxillary heat is an electric heat strip that provides heat to your home while the heat pump is in defrost cycle or if there are extremely low temperatures outside. Try not to set the temperature more than 2 degrees above the actual temperature of the room. Hope this helps.
Jan 25, 2013 | Honeywell Programmable Thermostat Heater
Amana heat pump emergency heat comes on but blower will not start. The call for heat comes in and the heating element(s) glow red for a few seconds and then there is a "click" and the heating...
Check the blower motor capicator. It should be mounted close to the motor with 2 wires to it (brown,brown/white).
Turn the blower on the thermostat and spin the squirrel cage by hand and see if it runs after by itself. If it does then definitely the capicator is bad .If it still doesn't run then check to see if there is voltage going to motor.
If thermostat is calling for fan and there is voltage present at the motor terminal then the motor is bad
Jun 01, 2017 | Heating & Cooling
Is the heating coil on my furnace supposed to come on before the fan or visa-versa?
Heating coil comes on first. When heat gets to a specific level, fan comes on. Fan stays on after coil is de-energized until heat drops back to that same specific temperature.
Charlie
Feb 20, 2011 | Intertherm Heating & Cooling
Fan come on no heat come out
well you need to establish heat source is coming on so fan can take heat if heat source coming on you may have a blocked heat exchanger get it serviced an problem should be fixed, if heat sourc not coming on you definatly need service agent
Nov 22, 2010 | Heating & Cooling
Heat light switch comes on..but the heated seat is
MORE THAN LIKELY THE HEATING ELEMENT HAS MALFUNTIONED. ITS A PRETTY COMMON PROBLEM IN HEATED SEATS
Nov 29, 2009 | 2003 Ford Expedition
When I turn the air on the heat strips comes on at the same time
Is this a central heat? From the size i assume it is.
You say air conditioning on part of your question then use heat pump on another part. So it is important for us both be on the same page.
With all due respect some people think they have a heat pump and it is just AC and electric heat also but is not a heat pump.
. If you have the outdoor AC unit running with your thermostat set for heat and the air coming off the out door unit is cold, or you see it "steam up outdoors" off the out door unit at times (we call this mode defrost).
If you actually have a Heat pump system some times it is wired to have the strips come on at the same time the heat pump comes on especially if you experience a lot of weather below 40' occasionally and have an emergency heat setting on your thermostat you most likely have a heat pump.
If you have a heat pump for sure now the heaters can come on with the outdoor section if
1 they are wired to do so or
2 the thermostat has 2 stage heating and the second stage is telling the elements to come on, or
3 the outdoor thermostat (if so equipped) is telling the elements to come on.
Any 1 or combination of these 3 items can cause the elements to come on wit the out door unit.
Mar 12, 2009 | Coleman Heating & Cooling
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
37 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
