Shuttle ab60r manual - Computers & Internet
Shuttle av 41 motherboard manual
1) http://us.shuttle.com/Scgsupport/Support2.htm
2) http://www.shuttle.eu/support/
A) http://www.shuttle.eu/_archive/older/en/av41.htm#av41
Specifications, but no motherboard manual.
[Navigation > AV41 > Download > English Manual AV41 (PDF 1938kB) = No ]
What specifics do you need? Front Panel header pinout?
Regards,
joecoolvette
Sep 10, 2012 | Shuttle Computers & Internet
English Manual for Mainboard FB65 (PDF, 3.5 MB)
Shuttle motherboard FB65 spec's,
http://www.motherboards.org/mobot/motherboards_d/Shuttle/FB65/
Link to motherboard manual in English,
http://www.shuttle.eu/_archive/older/en/fb65.htm
Scroll the page down until you reach the Navigation heading.
In the list left-click on - Download
In this list left-click on - English Manual for Mainboard FB65 (PDF,3.5MB)
Nope, doesn't work. Obviously Shuttle is after the almighty $$$$$, and doesn't want to support their motherboards, or people who buy them.
Note to self; AVOID Shuttle computers like the PLAGUE.
Regards,
joecoolvette
May 21, 2012 | Computers & Internet
Can someone give me a link for the shuttle ab60n v1.1 user manual? thanks
Hi, i did find some info:
Shuttle AB60N/AB60R Specification: The AB60N/AB60R comes in these configurations with a fixed retail price range. This configuration Shuttle provided was complete with a Intel Pentium 4, Intel Celeron Socket 478 Serial ATA, Ultra ATA/100 PCI/AGP n/a, .
The Motherboard add up to 4.0 GB memory, with standard 0 MB (removable) memory installed PC2100/2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR
Here is some driver links:
Your board has Realtek ALC650 with AC97 codec for sound. You should be able to download your driver here:
http://www.realtek.com.tw/downloads/
You can try older versions here:
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
More recent version here:
http://download.cnet.com/Realtek-AC97-Audio/3000-2110_4-103526.html
And more: http://www.shuttle.eu/_archive/older/en/ab60.htm And a intel site: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng Hope this was to any help
Aug 11, 2011 | Shuttle AB60N 865PE Motherboard
I need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Jan 25, 2010 | Sewing Machines
Memory Error but memory is fine
The number of beeps tells you what's wrong. Try this site from another computer.
http://www.computerhope.com/beep.htm
Nov 12, 2009 | Shuttle AV40 Motherboard
AB60r Motherboard does not find my hd
Hi, r_n_o,
The first thing to look at is your pin settings. Make sure that if it's just a single drive that it's set to Master. If there are two drives make sure one is master and one is slave. If it's a SATA drive, make sure that you open your bios at boot prompt and make sure that Bios is looking at that drive to boot from.
The the amount of informtion that you left us, that's the best I can tell you. You should always post all information on what equipment you're trying to work with. Drive name, type, etc.
Good Luck,
Mark
Oct 09, 2009 | Shuttle AB60R i865PE Motherboard
"Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Jul 06, 2008 | Printronix Line Matrix P5005B Printer
Manual for Shuttle MK-40V motherboard
Hi Angie8,
Click on the link to download you're manual for Shuttle MK10VN.
English Manual MK35N (PDF, 7 MB)
Click on the next link to load all drivers & downloads for you're Shuttle motherboard.
http://eu.shuttle.com/archive/en/mk40vn_faq.htm#download
Enjoy!
Mike
May 03, 2008 | Shuttle MK40VN Motherboard
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
