Facia Brightness How do you increase the brightness of the facia display on a C-D31??.
Pyrhyc
  • 2028 Answers
SOURCE: xps screen brightness low
Press F2 at start up to go into the bios. There is another setting in the bios for the screen brightness while on battery power.
Posted on Jul 15, 2008
  • 62 Answers
SOURCE: brightness display comes on by itself and won't turn off
1. Adjust the LOT screen preset.
2. Trace the G1 path , LOT to neck board. Sum times diode are capacitor problem.
3. LOT sarounds one 10Mf / 450 V capacitor bad
Posted on Oct 14, 2008
kevin000
  • 1847 Answers
SOURCE: After being dropped Fn keys no longer control Screen Brightness
Try change the brightness from the BIOS and let me know the status
Thanks
Kevin
Posted on May 27, 2009
  • 355 Answers
SOURCE: Monitor Contrast and Brightness Problem
service your monitor your monitors cadr is problem
Posted on Oct 02, 2009
  • 1149 Answers
SOURCE: screen brightness is low bearly vissible,i tried
Hi:
It sounds like the inverter or backlight has failed on your laptop. Try to connect an external monitor to the laptop to verify this. You should be able to toggle between the two displays by holding your function key down, then hitting the crt/LCD button. If the external monitor works good, then you have had a hardware failure.
Posted on Nov 12, 2009
Screen not bright auto-brighness not working
To increase the brightness, either swipe up from the bottom to get the control panel, and increase the brightness there (slide the slider just below the 5 circles to the right) or go into Settings > Display and Brightness> Increase brightness using slider. You can also turn on the auto brightness from here if it is off, or turn it off if it is not working like you want it to.
May 13, 2016 | Apple iPhone Cell Phones
Adjust screen brightness
go to start-->control panel--->display--->adjust brightness
i need to know what operating system you use this will work for only Vista and 7 and 8 and 8.1
Oct 10, 2014 | IBM ThinkPad T40 2373 Notebook
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
Bad home key on thinkpad g41 keyboard is there an alternate way to increase brightness?
Try using Thinkvantage Application to adjust as follows:
ThinkVantage Control for Display Brightness
  • 4 Click the "Start Menu," then click "All Programs" and locate the "Access IBM" program group.
  • 5 Click "Thinkpad Configuration" and click "LCD" to open the brightness control dialog. Select the brightness from the drop-down menu and click "OK."
  • 6 Click the red "Exit" button in the upper-right corner of the Configuration utility to close it.
Read more: How to Adjust the Brightness on an IBM ThinkPad Display ' eHow.com http://www.ehow.com/how_5818403_adjust-brightness-ibm-thinkpad-display.html#ixzz277iQ4g48
Sep 11, 2012 | IBM ThinkPad G41 Notebook
Detachable face does not work.
Unfortunatley, detachable facias do fail from time to time.
The important thing is to ensure the facia is locking "tightly" to the head unit and making good contact with the copper pins.
If your model facia is not the pin connection type, but has the ribbon cable, then the ribbon cables are easily relaceable (these were a common repair item).
If there is an internal issue with your facia, then have it checked for "dry joints" - this is where over time, a solder joint has dried up and not making proper contact.
Whichever repair is required, always price up a replacement facia first, as this is sometimes cheaper than paying someone to inspect and repair your faulty facia.
Cheers,
Jun 14, 2011 | Dual Electronics XDM6400 CD Player
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
How do you remove the front facia door of a Teknik integral dishwasher
I have just replaced the facia on mine. It is a TKD795/4 so I would imagine yours would be very similar. Around the inside of the door are 10 starhead screws; 4 along the top and 3 down each side. On mine it is the 2 end screws along the top and the 2 middle screws down the sides that hold the facia on. It is best to remove one screw at a time to establish which ones hold the facia on and which hold the door together. The short screws hold the door together and should be replaced and left in place. It is the longer screws that hold the facia on; these only need to be undone enough to release the facia panel. Once you have undone the relevant screws, the facia will lift up enabling you to release the 2 clips at the bottom. Replacement is reverse of removal. Hope this helps.
Feb 26, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
-tries to read dvds but can not -face won't come off
if the unit is new there are 2 screws in case to be removed before cd will work, they should be labe;ed on cd player, also there is a screw that prevents the facia being removed , that screw is not normaly in the new unit, but the shop selling it puts it in to stop the facia being taken off while on display . its not marked but is just normally on the top of the case behind the "button" you press to release facia
Dec 26, 2009 | JVC KD-AVX1 Car DVD Player
Need best settings for a Panasonic TH-50PZ85U
As with any display best settings are up to the user.
Some general rules about adjustment of a video display device apply
1. if the display is too bright you would decrease brightness by turning it down
2. if the display is too dark you would increase brightness by turning it up
If a display is too bright it will shorten it's life span so you want to keep the brightness down
Contrast must also be adjusted in the same manor
You should increase color saturation to suit your self
Increasing the color saturation too much will decrease the life of the display and look ugly
so you want to add just enough color to satisfy your taste.
Loch Hiam :-)
Sep 14, 2008 | Panasonic Televison & Video
FACIA
If you have the new facia cover it is easier than you think. Take a flathead screw driver and gently start lifting the facia up from the key pad.
May 23, 2008 | Nokia N73 Cellular Phone
 Grubhead
Grubhead
