TCL l32e2000 tv. When I set it to record, it starts at the correct time but stops recording after a couple of minutes. Each time I set it to record for at least one hour. It starts at the right time but won't keep recording to the right time. What am I doing wrong?
  • 27 Answers
SOURCE: Reciever Not Recording
Turn off the receiver, unplug the receiver, wait 30 seconds, plug it back in, and go through the setup again. This hard restart clears the memory and restarts the DVR software(clears any software glitches) This should fix this problem assuming that your satellite signal is good. Check that during the resetup. Most transponders will show between 70 to 100 signal strength. (Minimum is 70 for error free reception) Several transponders will show 0 as they are dead on the satellite, and not a receiver problem) If your satellite signal is in the 70's or less, you either live in Maine or you may need to realign the dish or something is blocking the signal like a tree or bush growing that is partially blocking the signal causing the signal to drop out(partial recordings)
Posted on Mar 09, 2007
SOURCE: voice recorder icd mx20
Sony has posted the intructions at http://www.iq.sony.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=77,E=0000000000714635791,K=6871,Sxi=1,Case=obj(411462),VARSET_OBJ=411462,VARSET_TSRC=results,UseTemplate=case.tem,VARSET_TOP=TRUE The steps aren't very intuitive and they are not in the cocumentation that came with my unit.
Posted on Oct 05, 2007
SOURCE: This is suppose to hold hours of recording time and mine only holds a few minutes. How do I increase the time?????
Two things to try: make sure you have a big enough memory card for the intended format and recording time. I suspect you are trying to use the 16MB Compact Flash card that came in the box. A 1GB card will record much longer than the battery life in the Microtrack 24/96, even when recording 24-bit stereo in WAV format. If you have a smaller card, and want long recording times, use an MP3 format. Using the MP3 encoder, monophonic recording, 128K bits/sec, 44.1K samples/sec, you should be able to record over 16hrs of audio on a 1GB memory card. Same card, WAV encoder, 44.1K samples/sec, stereo, 24-bit audio will produce only a little over one hour of recording time. With the 64MB card that came with the recorder, the most you can record using WAV encoding, 24-bit audio, 44.1K samples/sec, is a little less than 4 minutes. With 16-bit audio about 6 min, and with mono and 16-bit audio about 12 min. With WAV, 24-bit audio, mono recording yields 7:52.
Posted on Jan 02, 2008
  • 226 Answers
SOURCE: dvd/vcr recorder stops recording
DVD-RAM itself, and DVD-R formatted in "VR" mode are SUPPOSED to allow for recording "ONE TIME" per DRMA. The broadcasters are probably sending the wrong copy protection signal if the -RAM & -R/VRmode are stopping.
At least, that is my understanding.
tom
Posted on Jan 10, 2009
SOURCE: TV Guide onscreen is the wrong time
I've had this problem before, and always fixed it by going through setup again, setting the zip code to another zipcode nearby, and turning it off overnight. By the next morning the time has fixed itself. This is the only thing that has worked for me consistently.
Posted on Feb 27, 2009
When I record programme from the tv it always cuts of at least one or two minutes before the end of the programme is there any way to fix this
Try setting the time of your DVR to be precise. If the recording starts 2 minutes before the show starts it will cut off 2 minutes before the show ends! My DVR has functions that allow me to add a minute or two before or after the times set to record, but that can cause other problems like if you are recording 2 shows and you try to record a new show after a show that was being recorded, it won't allow you to, because it can only record 2 shows at a time! Best bet is tro synchronize your watch to the Internet time and use that to sync your DVR time.
Dec 03, 2015 | Televison & Video
How do I record on a TCL Model L32E330, using a USB stick
Use the timer record function in the tv guide or timer reord in menu on unit
Jun 02, 2014 | LG Tcl L40fhdf11ta Tv Part Main Board...
HOW DO I RECORD USING USB STICK ON MY TCL TV
go into the tv guide menu and there should be a option to record
Dish changing channel to new recording while watching *pre-recorded* program
rjvdw,
Try unplugging the receiver for 10 seconds then plugging it back in, and see if the problem is resolved. The receiver should only switch if you are watching live TV instead of a recording.
If the problem persists, and you are for sure not on Live TV, the receiver may need to be replaced. If it continues you can send me an email at thomas.faust@dishnetwork.com, and I can assist you further!
Tommy Faust
DISH Internet Response Team
Jan 23, 2012 | DISH Network 54 1 Ir Vip 622 722 Dvr...
My dish network dvr stops recording some programs, i think its just shows that are to be recorded on tv 1. It will record only like 10 minutes or less and stops recording
jeff_rhondac,
Check the timers you have setup for the programs that are suppose to record. Make sure the timers are setup correctly. Do you have any timers setup to begin early and end late? A new software update rolled about 2 weeks ago. Did you start experiencing the problem after that? Also, how much available time is available on the HD? Please let me know so I can further assist you.
Thanks,
Ray Calo
Jun 24, 2011 | DISH Network ViP722 DTV Receiver /...
Doesn't stop recording
Make sure there is no time overlap on any of the programs you have on the recorder.
That is the most likely problem
Aug 19, 2009 | DISH Network DVR-625 DTV Receiver /...
I MISPLACED MY USER MANUAL
You have to go the main menu and select record times, and day. Make sure you leave your tv set on, and on the channel that you wish to record the program on. You can set the start and stop times a few minutes before and after on the vcr, just to make sure you get the whole program. You can also set the vcr to record this program every day, any day of when ever you wish you can just manually hit "record on the vcr remote. Good luck, let me know how you make out! Thanks
Aug 12, 2009 | Televison & Video
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
Toshiba 13 inch tv/vcr quits recording audio
Does the audio "cutout" suddenly, or does it ''drift" off and on?...accordianman
Feb 28, 2008 | Toshiba MV13L3 13 in. TV/VCR Combo
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
