Question about Eo Sanitizing Hand Wipes Organic Lavender 3 pack
How to disable auto shut off on soft heat heating pad
I am trying to find out how to disable the auto shut off on a SoftHeat HP218 heating pad. I have found videos on a different model but this one has more pins on the chip than the one on the video.
How can I disable auto shut off
Just note the chip number and Google it for the data sheet.
when you found the actual data sheet read the pinout diagram of the chip to find out the Vcc pin.
you have to cut the link of Vcc pin of the chip and the chip will stop working.
Feb 15, 2014 | Softheat Heating Pad HP218 12 3P
How long does the soft heat wrap ultra need to be microwaved
Typically, for anything, I try 15 seconds (below 100g ), if not sufficient 30 seconds and progressively more as function of weight ( one to two minutes for 300g) , testing the not burning temperature with your hand.
It is very burning to try several minutes abruptly without testing progressively. You can even have explosions, in particular with eggs !!
Feb 13, 2014 | Kaz SoftHeat Ultra Back and Hip Wrap
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
Electric blanket won't heat
Take the help of your mattress pad company or look into instruction manual. Do not operate it unless you are familiar with it. You should call the customer care to know how to operate.
Jack from Coriumdirect Mattress pads
Apr 07, 2013 | Biddeford Blankets Heated Mattress Pad...
Light is flashing on temperature control of heating pad
Trust me! This thing is a piece of ****! I bought one and loved the heat options that I bought three more for my wife and two daughters and their families. The next day mine went out. Took it to Walmart and traded it for another. Still pretty happy, figured I got a bad one. Three months later not a single one is working all have blinking green lights and won't allow you to do ANYTHING but unplug it! Five and all died the exact same death. Go to Walmart and each time they act surprised! NO WAY!!! This is a chronic problem with this product. I'm contacting the company tomorrow and am going to demand an ecplaination as to why they have not take this item off the market!
Jan 07, 2012 | Softheat Heating Pad HP218 12 3P
Is there any way to disable the automatic shutoff on drip coffee
mine decided to disable that function altogether, and it wont shut off unless I unplug it. Nice, safe piece of ****, Hamilton Beach!
Apr 02, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Eo Sanitizing Hand Wipes Organic Lavender 3 pack Logo
277 people viewed this question
Top Eo Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Eo Health and Beauty Expert? Answer questions, earn points and help others
