Question about Bernina Sewing Machines
Need a wiring diagram for a bernina sport 801
    Scholar:
  • 74 Answers
You will probably find the information that you need here: BERNINA Startseite Herzogenbuchsee Info BERNINA Service Tipps Lenco...
There's a great deal of information about the mechanical Berninas but the site is in German. It will be worth your perseverance though.
Posted on Jan 02, 2015
4 Suggested Answers
RickE1
  • 202 Answers
SOURCE: I have bernina sport 801 machine and need to know
You can oil any two metal parts that move togeather or through each other. Do not oil bearings and do not oil gears. Do not use 3 in 1 oil or WD-40. Use regular sewing machine oil.
801's were made from 1979 - 1982. The way Bernina dated these on the machine is by the serial number. Your number would probably start with a 0 or a 1. 1970 is a 0, 1971 is 01, 1980 is 1, 1981 is 11, 1990 is 2, 1991 is 21 etc. etc.
Rick
Posted on Oct 08, 2009
Zenqi
  • 208 Answers
SOURCE: I have a bernina sport 801 and the fabri feeder
There is a small knob on the lower part of the main body under the stitch length lever. This controls the feed dog up or down. Make sure that it turns easily and fully to both positions. If it does and your problem persists, the feed dog height adjusting point is probably loose. A knowledgeable repair person needs to look at it. It is not a difficult repair, but several approaches need to be taken.
Posted on Jan 09, 2010
SOURCE: My Bernina sport 801 is
clean under the needle plate
clean the bobbin area for loose threads or lint
if this doesn't make the noise stop then it may need to be serviced
Posted on Aug 03, 2011
Where can I find a service manual for a Bernina 801 sport?
It is difficult to find service manuals because they were reserved for service/repair personnel. Finding them for older machines is even more difficult. You may find one on the secondary market, ie eBay, Etsy, etc. However, you may have some luck by joining the BerninaThirtySomethings group on Yahoo. The members on that group are very helpful.
May 24, 2016 | Bernina Sewing Machines
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
How do I remove the top on a Bernina 807 in order to chnage th elong belt ?
V-Belt replacement 801/801 Up Machines
Only the belt cover needs to be removed for this belt change. This is done by removing the three screws on the end/belt cover. Loosen the 5mm Allen socket head screw below the step pulley to relieve the belt tension. Remove the lower motor belt. Lift the step pulley and slide off the hand-wheel, (assuming that you have already removed the release knob and clutch ring).
Additional top cover removals 807/801 Minimatic machines
Early 807 machines had two expansion nipples in the top cover that fit into receptor holes in the upper arm frame. Simply pull up the top cover.
Very late models may have a push button latch mechanism, same as on the 801 machines except those fitted with carrying handles, i.e. 801 Sport, 810 machines.
This is accessed by opening the light cover and finding an aluminum knob in the upper left hand corner of the upper arm frame. Push this in and the cover will release. Lift off the top cover.
Sep 10, 2015 | Bernina Sewing Machines
How to thread bernina sport 801 bobbin
All the CB machines are threaded in a similar way. Here's a Youtube video illustrating the process on a 1008. Plenty of other examples on Youtube too.
Apr 28, 2014 | Bernina Artista 180
I have a bernina Sport 801 and my bottom tension is off. I'm not sure how to fix this. Adjusting the tension setting doesn't seem to work.
On the bobbin casing is a screw to adjust bobbin tension when upper tension will not solve the problem. Check your manual for location of the screw.
Aug 22, 2013 | Bernina Artista 180
Hand wheel will not release on my bernina sewing machine what should I do?
If handwheel is difficult to turn manually, it most likely needs cleaning and oiling.
Oct 11, 2012 | Bernina Sewing Machines
My Bernina sport 801 is making a loud screeching noise heard under the presser foot/bobbin area
Aug 03, 2011 | Sewing Machines
Jan 09, 2010 | Sewing Machines
Rick
Sep 20, 2009 | Bernina Sewing Machines
Sewing Machines Logo
254 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
