Question about LG WM3470HWA Front Load Washer WM3470HWA
LG Washer gushing water out of the lint trap in bottom left corner
Yesterday I cleaned out my lint trap on the bottom left corner of my machine and when I put the trap back in and turned it it felt different. Like there was no tension....we read about it and thought maybe it was the circulation pump...replaced it still gushing water. Is there a gasket in the lint trap that can go bad? Or do you have any suggestions on what else it could be? Thanks for you help!!!
  • LG Master
  • 15,941 Answers
Get a flashlight and check the fittings. Yes there is a gasket.
Posted on Feb 15, 2014
4 Suggested Answers
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
SOURCE: LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Posted on Feb 01, 2010
  • 5 Answers
SOURCE: LG WM3677HW Pump Problem
No need to go in through the top to remove the pump on a WM3677... i've removed mine seems-like a dozen times already, and will soon replace it.
Be sure all the water is out of the washer before starting.
We have a training problem with not cleaning the lint trap, and the pump gets jammed. The design is bad; it traps some REALLY nasty gunk underneath the impeller (in the cavity).
Anyhow, when facing the machine, put a low step-stool to the right of the washer and (carefully!) tip it over onto it's side, resting on the stool. Pad the stool with a towel, if you're careful.
The pump is in the bottom of the machine, towards the front/face on the now-higher side. That's the left, as facing the machine.
First, remove the lint-trap, and the plug in the drain line (small black hose). Remove the access-panel plastic piece, it is held in by one small phillips screw.
Note the 4 wires attached to the pump. Remove them, they are spade-connectors. Note the color/position if you like, but it's not really important.
Reach behind the pump and pull off the small hose. This is the sprayer, and it does not have a clamp on it.
Use large channel-lock pliers to compress/slide back the clamp on the large rubber hose that goes from the drum to the pump. This is the supply/suction side. Remove the hose, but be sure not to dislodge it from the bottom of the drum.
The ribbed hose also has a compression clamp. This is the drain hose.
Remove two of the three phillips screws that hold the pump in, they are under the plastic panel we removed a minute ago, on the front of the machine.
Holding the pump with one hand, remove the last screw. The pump is free.
Assembly is the reverse, and don't forget to put ALL the hoses back!
Posted on Apr 08, 2010
My LG Tromm washer does not drain all of the time. When is doesn't drain the water smells really bad. If I use a higher spin cycle setting it will usually drain, but that is beginning to not work either....
One thing LG did was install a manual drain hose located in the bottom left corner where the lint trap is, you can pull out the small hose and drain the machine that way, also, leave the door open on the washer slightly, this will allow the unit to dry better and eliminate odor, another cheap cleaning and odor elimination, pour 1/2 cup of chlorine bleach into the drum (with out clothes) put it on a short was cycle, the bleach should clean any bacterial growth; make sure to only due a white wash following this procedure to make sure that any possible bleach remaining dosen't effect color clothers....
Dec 08, 2013 | LG WM1814CW Front Load Washer
Wont drain the indicator says the hose or filter is clogged
You can drain it manually with the little trap at the bottom of the washer and verify if there is anything in that trap. Make sure you have a bucket or something underneath because water will gush out.
Mar 15, 2011 | LG WM2688HWM TROMM SteamWasher
My LG washer lost all power while running. Checked breaker. Is OK. Power good at plug.
There is probably a little trap door on the front of the machine right near the bottom. Behind this, you will find what looks like a large screw cap. If you undo that, you will release the water from the machine (it's the lint trap), so be prepared for a lot of water with a few buckets or bowls that you can put under it. Once the water is out, the door should release
Sep 13, 2009 | LG WM-2277HW Front Load Washer
How do we clean the dryer 's filter?
I think I know what you mean - the machine itself does not have a lint filter and over time I've noted that it can build up around the large rubber door gasket. You will simply need to be more fastidious about cleaning it out after each cycle. I've had success using an old toothbrush dunked in some water to get the stuff out. The washer's filter (located in the lower left corner of the machine) only traps large solid debris. Hope that helps!
Jun 26, 2009 | LG WD-3274RHD Front Load Washer / Dryer
LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Mar 19, 2009 | LG WM-0532HW Front Load Washer
The control lock does not work. Tryed everything to unlock the
It is not inlocking because of water still in the system, run the drain spin cycle manually if that does not work you will have to clean out the lint trap and the water left inside will drain on your floor. To clean the lint trap. there is a panel at the bottom front of the washer. along the bottom of the washer there are three torx type screws to remove the panel these will be above the drawer unit if you purcased the stand. remove the panel by lifting from the bottom. then in the center you will see a plastic cap. twist the cap to remove. this is your lint filter. it pulls out and has a cup shaped piece attached to it pay attention to how it comes out im not sure if you can put it in wrong. clean the area out. there may be some water to spill out depending on how much is clogged in your system. replace the cap once you have cleaned it out this should help with your problems.
Mar 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG WD-12331. Front load washer and dryer machine
since it is a washer-dryer, the lint trap is in line with the drain. you have to empty the drain basket. there's an access door on the bottom left, first take the little tube out and drain the remaining water, then open the large drain cap to the right and clean out the trap. once you're done put it all back together and it should work. you're supposed to do this every few months. It was too much for me to deal with so i ended up buying a separate dryer and just use the washer .
Jul 28, 2008 | LG WM-2277HW Front Load Washer
LG WM-3677HW dryer cycle does not dry and lasts for 3 minutes
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
And rate me pl ...........if helped.
Oct 23, 2007 | LG WM-3677HW Front Load Washer / Dryer
Lg Front loading washing machine
most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Aug 04, 2007 | LG WD-1080FD Front Load Washer
LG WM3470HWA Front Load Washer WM3470HWA Logo
123 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
