Question about Asko 24 in. D3250 Built-in Dishwasher
No power Close door and turn on, Buttons do not light up and nothing happens.
Dish washer cycle wont start
will it not start because of power?
or buttons light up but no start? what happens when you press start? Light up? If no light, that' where the problem is. Try other buttons if they respond differently. Lastly are you sure you close the door securely?
Aug 07, 2013 | Bosch Dishwashers
Won't turn on
Try just pressing the selection pad, without pressing start/cancel and close the door. That has worked for me a couple of times.
May 05, 2010 | Frigidaire Professional Series 24 in....
1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Apr 04, 2010 | Panasonic NN-S262SF Microwave Oven
All the lights and buttons on the front of my Frigidaire PLMBZ209GC work but the turn table does not turn and the fan does not run and it does not heat. It counts down and the cook light beside the timer...
Hello :
That problem could happen because of a bad door switch .
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 31, 2010 | Frigidaire Built-In Microwave
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Asko 24 in. D3250 Built-in Dishwasher Logo
26 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
