Question about Hotpoint RGB745 Gas Kitchen Range
F2 code and alarm
Pre=heated oven to 425, put pizza in and set timer for 12 minutes. After about 10 minutes an alarm started ringing and an F2 code showed on the timer.  Turned the oven off, checked the broiler everything ok.  Oven seems to be working ok.  burners are working ok.  What should I check? Is it the timer?  Thanks.
  • 1 more comment
  • Anonymous May 26, 2008
    Had same scenario, only difference was I think I was putting a steak in instead of pizza :), and likewise got the alarm to stop & everything seems to work ok. Is it an indicator something is about to fail? (Be my luck it will muster thrutill THanksgiving morning! So it would be nice to know would rather be proactive in replacing anything that is questionable.}
    Thank you! Hope someone has some words of wisdom to share on this issue!
    However Mine is free standing electric range 911.94465 (model #)
    Is it an indicator something is about to fail? (Be my luck it will muster thru till Thanksgiving morning! So it would be nice to know. I would rather be proactive in replacing anything that is questionable.}
    However, Mine is free standing electric range 911.94465 (model #)
  • Anonymous Mar 29, 2014
    Set oven timer and it set at 12 hours. I want to turn it off
  • 83 Answers
Samsung un55f6300afxza sometimes won't turn on
It is a common problem with a defective main board. You may re-flow the soldering yourself by this procedure.
Re-Flow Soldering Procedure for Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
Aug 31, 2017 | Samsung Televison & Video
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
Convection oven does not get warmer than 200 degrees even when set on BROIL
The service manual is here: http://www.microwavecontrol.com/dcm24_r930ak_aw_sm.pdf
You may have a failed thermistor.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 01, 2017 | Sharp R-930AK Convection/Microwave Oven
How do I start the oven? I want to cook a pizza
Open the oven and make sure it is empty nod one rack is near the middle level. Turn the knob that says OFF to BAKE. Then turn the knob with all the numbers to the temperature that Theo Sri toons on the box tell you to use. Allow the oven to heat up for 10 minutes. It may beep when it is up to temp or a red light will turn off to let you know it is ready. Put the pizza in the oven on middle rack. Take it out according to box instructions ( usually 8 to 15 minutes). That pizza out by sliding it onto a plate. Turn off the oven and eat the pizza. If it is not done completely, leave it in longer next time. Enjoy
Jul 08, 2011 | Ovens
No instructions with Paderno pizza stone!!!!
Nothing to it. Just pre-heat the stone for 15-20 minutes at 425-450 degrees. Slide your prepared pizza onto the stone and cook. ps best to prepare your pizza on a pizza peel or cookie sheet so you can slide it on to the stone. Cook around 10 minutes or so. Good luck and enjoy your pizza.
Mar 08, 2011 | Vacuums
How do I change time on a KADIO clock 3809
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
Why does food get hard after cooking or reheating in a microwave
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with foil....in the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
Sep 08, 2010 | Whirlpool Ovens
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
Hotpoint RGB745 Gas Kitchen Range Logo
520 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
