Question about Lionel Cw 80 Transformer
Lionel cw80 80 watt transformer primary fuse
Looking for fuse value (amps) Thinking slow blow (MDL?) is way to go.
2 Suggested Answers
  • 13 Answers
SOURCE: is lionel 40 watt transformer from toy train
need a larger out put transformer 90 watt or greater....
Posted on Nov 20, 2011
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
Have a hartke lh1000 head . played about 5 total hours then blew the fuse. is this something i shoud be worried about?
If the fuse is correct ( check manual) it shouldn't blow under normal operation. Once in while a fuse will break internally and thus blow the fuse. look close at the blown fuse If it is a "violent" blow (totally black inside) then you have an overload condition. I would use an ohm meter to check the connection to the speakers. Usually it should be between 8 ohms and 4 ohms if the number is lower than 4 ohms your speakers or wiring are putting to much of a load on the amp. If the fuse was not a "violent" blown fuse then replace with a new fuse of the exact proper value. many amps use an MDL fuse that is a slow blow fuse and has much different in circuit function than a ACG fuse so use only the exact proper furse that the manufacture recomends. If the load (speaker and wiring) is correct and the fuse is correct and still blows then you have a component problem and the amp will need repair
Jan 19, 2012 | Hartke Lh1000 Bass Amp Head 1100 Watts...
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
MTX Lolita Sub amp defective power transformer (open primary) What's the transformer voltage?
Without Knowing the Output Chip or transistor Numbers, I don't know but Most 100 Watt anps use 60 to 70 Volt Centertap Sacondarys. Also if You Take the Cover off The Transformer you will find a Thermal Fuse in the Primary. I have bypassed the Thermal Fuse and went with a external fuse, Go for it.
Oct 07, 2010 | MTX LOLITA 8" 100 WATT LOW PROFILE...
20 amp fuse blows, by passed it, oven only taking 15.79 amps....what could be the reason, for the blown fuse? I was thinking it could be the F2 relay, any help would be nice...thank you.
this is somewhat odd did you replace the 20 amp fuse and now it works. test the primary side on the hv transformers. you may notice some signs of burning on one of the hv transformers
Jan 05, 2010 | TurboChef TORNADO Electric Oven
Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
May 23, 2009 | Microwave Ovens
My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Nov 18, 2008 | Lionel Cw 80 Transformer
I have a digitor subwoofer (A3111) and it looks like the fuse is blown. Looks like it needs a "F1AL 250V" fuse - but when I looked for one in the shops, I couldnt find it. Do they still exist?...
Firstly, the fuse is just a slow blow 1 Amp short style. You should be able to get an equivalent at any electronics parts supplier (a 1.25-1.5 Amp will do as long as it is the correct physical size).
Secondly, the cause of it blowing the mains fuse is probably a short in the primary winding of the Toroidal transformer. I have now replaced the transformer in mine twice over about 4 years.
If you cannot get the original Toroidal transformer (with the correct connectors) use a 50 or 80VA 12+12V Toroidal Transformer and connect the secondary windings in series. You should be able to get one for AU$30 to AU$40.
Oct 05, 2008 | Audio Players & Recorders
Yamaha P-4500
Hi radek
If it is a toroidal,they have a nasty habit of going shorted turns on the primary. Is it blowing fuses? Let me know
robotek
ex In'gill ;)
Sep 12, 2008 | Yamaha P4500 Power Amplifier 2-Channel
Nad 218 thx power amp keeps blowing ac plug fuse
Hi there. From memory they had bridge rectifier problems with them going short circuit. Check them first. Sometimes the toroidal transformer can go a shorted turn, in turn blowing primary fuses. try to soft start it whilst it is blowing fuses, Best bet is to make up a special lead that has a 60w light bulb wired in series with the mains power supply(or across the fuse holdwer that is blowing:). Limits the power in the circuit to ... well you guessed it 60 watts.
check em out and let me know.
regards
Graeme
Apr 27, 2008 | Audio Players & Recorders
Lionel Cw 80 Transformer Logo
144 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
