Question about All-Power America All Power 10000w Apg3090 Electric Start Generator
Allpower American. 10000w generator won't start? Changed spark plug, gas is flowing. What else can we try?
  • 37 Answers
Make sure it has plenty of oil. Some engines have a low oil shut off. Pull the spark plug wire off and stick a screw driver down inside the spark plug boot and hold the screw driver about a 1/4 inch away from the top of the spark plug and turn the engine over to see if you have a good bluish spark. If you don't then you have a bad coil or rust build up on the flywheel. If you have spark make sure your gas tank is full with new gas. Make sure the air filter is clean. If that doesn't work try taking the bowl off of the bottom of the carburetor and verify gas flows through the float valve. If that doesn't work then you will probably have to remove the carburetor and clean it out.
Posted on Feb 16, 2014
Where can I get an owners manual ?
PDF]10000W Generator
scene7.samsclub.com/is/content/.../GG10020-Eng%20manual-cpdf
Gentron/UPC will repair or replace, at Gentron/UPC's sole option, products or components ... Expendable parts or accessories supplied with the product which are..... FILLED WITH OIL OF A HIGH QUALITY SAE 10W-30 GRADE ENGINE OIL.
Gentron - 10000 Watt Gas Generator with Electric Start
www.samsclub.com > Sam's Club > Emergency Supplies
Sam's Club
Rating: 4.4 - ‎330 reviews
Gentron 8,000W / 10,000W Portable Gas Powered Generator with Electric Start ...... 1 year parts and labor limited manufacturer's warranty; For issues not ...
Gentron Pro2 10000w Gas Generator (GG10020)
https://generatornow.com/gentron-gg10020-pro2-10000w-gas-powered-...
Gentron GG10020 Pro2 10000w Gas Powered Portable Generator with Electric ... It's a one year/1000 hr parts and labor warranty for our residential customers.
Jan 21, 2016 | Electrical Supplies
How do I drain the old gas out and clean the carburator
dissconnect the fuel line into the tank after the valve and drain it. you might want to put in a high octane when refueling also u can try a lil methyl hydrate
Oct 16, 2014 | All-Power America All Power 10000w Apg3090...
My generator will turn over but wont start
Our motorhome Onan 5000 Marquis generator will turn over and try to start but fails everytime we test. We have primed, gas and oil are fine and we have new spark plugs. We also changed the gas filter on the generator. Any suggestion? Thanks, Loretta
Mar 30, 2014 | Watts Onan Portable Generator - 4000 ,...
I cant get my coleman powermate 5000 MAXA ER to start. i have changed the oil, refilled the gas, changed the spark plug, and tried using starter fluid. what else can i try?
It's almost certainly gummed up gas in the carburetor. Get some carb cleaner, and some spray instant start. Drain the gas from the tank and put a small amount of 50/50 carb cleaner and gas in the tank. Remove the air cleaner, open the choke, spray a little instant start into the carb and start it. It may fire just a couple of time. Keep the choke on to try to pull a bit of gas through the carb. You may have to do this a few times. Once you can tell some gas is flowing, open the choke slowly to keep it running until you use up the 50/50 mix. Then try a small amount of straight gas in the tank to be sure it works right, before you refill the tank. Make sure you use a stabilizing additive in any gas that you store for more than a month. good luck, Al K
Feb 02, 2011 | Coleman Powermate Premium Plus 6250W...
Wont start i have changed gas and spark plug
kill switch in proper position for run? fuel valve on if applicable?choke on ? sorry i had to ask. pull plug out ,connect plug wire and see if spark by grounding plug on engine, than a sharp pull from recoil- should see spark. good spark? if so- now see if fuel is reaching carb by removing screw on bottom of carb float bowel . this must be done out side - i know there is a blizzard going on. remember where all gaskets go and are properly on when putting back together. If no FRESH fuel FLOWS OUT WITH GAS ON your needle on the float shaft is probably stuck in the seat of the carb.Pull down on float gently to release needle valve.may have to shoot some carb cleaner in there. be prepared to shut off fuel if it starts flowing.If no shutoff ,pinch off fuel line with small vice grips or hemo's. all jets should be cleaned if old gas dried in bowel over time.
Feb 01, 2011 | Craftsman Electrical Supplies
All-Power America All Power 10000w Apg3090 Electric Start Generator Logo
130 people viewed this question
Top All-Power America Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an All-Power America Electrical Supply Expert? Answer questions, earn points and help others
