Need Remote Code For Avion LTV 320
Thank you..
  • 11 Answers
SOURCE: Code for a Gateway ADC-320 needed
Hi chris_vau888
You could try these codes :- 1100, 1104, 1185, 1221. If none of those work you could try the philips code lookup finder at :- http://www.urc.philips.com/ You will need the remote model number, either from the front of the remote or in the battery compartment.
Hope this helps,
Mark.
Posted on Mar 29, 2009
greg_margo
  • 1959 Answers
SOURCE: code for trutech 320 dvd player
This was a tuffy. The code I found was 1023. Good Luck!
Posted on Apr 15, 2009
  • 5 Answers
SOURCE: where can i get the power cord for it ?
If it's a standard power cable like used on a PC, go to Radio Shack.
Posted on Apr 26, 2009
westytech
  • 120 Answers
SOURCE: I need a remote code for a westinghouse LCD TV,
Hello, if the remote is a universal remote you will most likely need to input the Sony codes. Another option is to purchase an original remote at parts@wde.com, the price for the remote is $15 plus $5 shipping and handling.
Posted on Jan 26, 2010
SOURCE: Need remote code to program a universal remote for
******** keep the info yourself. Die you mother *******.
Posted on Feb 06, 2010
What are the lyrics to God is good to me by luther barnes
Looking back, over my life
I can see, how far I've come
I have had, some cloudy days
But oh the Lord has brought me, from a mighty long way
I've been up, and I've been down
But you never left me, you were always around
You stood by me, yes you did, through thick and thin
And I can truly say, that you've been my closest friend
Lord I know you've been so good to me
You've been so good
You've been so good
And I just want a thank you
I thank you
Oh I thank you Lord because you've been so good
You've been so good, so good
Let me say this right here
When I was down , I couldn't see my way
You stepped in and you made a way
That ain't all you done
When I was lost, I couldn't see the light
But Lord You stepped in, yes you did Lord, and you made my pathway bright
You've been so good
I know --you've been good to me
You've been so good
Right now Lord, I just want a thank you
I thank you
Oh I thank you Lord, Oh Lord I want a
thank you, Let me thank you I want a
thank you Lord
Yes I do Lord, Let me, thank you Let me
thank you
thank you Lord
Cause you've been so good, so good
So good
Chorus continues
So good, so good
Mar 31, 2017 | The Computers & Internet
Tip
Thank you, Thank You, THANK YOU!!!!!!!! You Helped me so much, If i knew who you...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Jul 18, 2008 | T-Mobile MDA
THANK YOU, THANK YOU, THANK YOU! FOR POSTING
Plese rate this soution as VERY HELPFUL if you are satisfied with the answers.
Sep 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Washer not draining - foul smell
It is so nice to get positive feedback from the people we work so diligently to help. Thank you, thank you, thank you!! And enjoy those earrings!!
Jul 15, 2009 | GE WSXH208A Front Load Washer
Copies=c555
thank u for encouraging us and using fixya.
Aug 08, 2008 | Canon MultiPASS C555 InkJet Printer
Thank you...thank you....thank you :)
You're very welcome. If you have anymore questions, feel free to ask.
Jul 27, 2008 | Compaq Presario 700 470024-192 Notebook
Sansa e260
It took me a few hours to crack these Sansa players, but with enough fiddling I have been able to recover many that were passed off as dead
May 10, 2008 | SanDisk Sansa e260 MP3 Player
Help
Could you elaborate on your problem?
Sep 06, 2007 | SanDisk Sansa e260 MP3 Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
