Question about JLab Audio Bombora Over-the-Ear Headphones
JLab boombora headphones left ear not working
My jlab (same set) does the same thing...any fix for it?
It works only via USB to PC because that is not only the way to transfer MP3 files from your PC to the player/headphones, but one way to charge the player's battery. You can also charge the player with the USB cable by plugging it in a USB wall charger. So let it fully charge in the PC or the wall charger and then take it with you while you walk, work out, etc. There is nothing wrong with your player (maybe the fact that there is no indicator when it is charging and when it is fully charged ??).
Dec 28, 2014 | JLab Audio GO Waterproof MP3 Headphones...
How can i fix my jbuds jlab headphones the problem i'm having is that i'm only hearing music from one headphone
I suggest you try them on another device to rule out the device receptacle (what your plugging it into) is not bad. Also, slightly pull them back a teenie bit so they aren't not all yhe way in and see if that changes what you hear.
Sep 24, 2010 | JLab Audio Europe JBuds Consumer...
Left ear bud does not work
yes a coil can burn out in secounds i think you have better have the unit looked at by an technition
Apr 21, 2010 | Sony Bud Style Headphones
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
Apr 15, 2010 | Bose Around-Ear Headphones - Silver
Only the left ear phone works
Try updating the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
Mar 31, 2010 | SanDisk Sansa e250 MP3 Player
JLab Audio Bombora Over-the-Ear Headphones Logo
26 people viewed this question
Top JLab Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JLab Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
