Question about Hoover Vacuums
Power cord warms up
I recently bought a vacuum cleaner the problem is when I am using it the power cord warms up to a point that freak me out. It happen in my bedroom when I was only trying to vacuum up the mattress. so, I would like to know if there is something wrong with it or it is just that the motor is too powerful. It is under warranty. MODEL # UH70935, HOUSEHOLD TIPE, SERIE YF12.0. Should I send it to a repair shop as suggested by Hoover or simply just leave it like that... I am concern it catch fire. please help me.
    Top Expert:
  • Hoover Master
  • 35,672 Answers
If it is under warranty, send it to a repair shop.
Posted on Feb 15, 2014
  • Hoover Master
  • 16,010 Answers
They do get warm and that is normal. You will see it melt before it catches fire. The amount of electricty that is being used is close to the amount the cord can take.
4 Suggested Answers
SOURCE: Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Posted on Feb 13, 2008
SOURCE: hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Posted on May 04, 2009
SOURCE: How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Posted on Apr 29, 2010
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Mar 21, 2016 | Dyson DC44 Animal Handheld Vacuum Cleaner
How do you fix a red Hoover windtunnel 2 rewind pet vacuum (model UH70830)? Since me and my 1year old corgi have arrived at my moms place, I've been using her Hoover vacuum cleaner off the hook because...
It sounds like there's a problem between the power cord and the vacuum cleaner itself. Remove the power cord check the connection at the vacuum cleaner and see if something came unconnected
Nov 18, 2014 | Vacuums
I recently bought this machine 2nd hand but the power cord is missing. Can I get one from a dealer or whomever?
Contact any vacuum ckleaner repair shop in your area and they can supply a replacement cord. Check the local phone book under vacuum cleaner parts retailers.
Mar 04, 2011 | Vacuums
Dyson has no power
The most common cause of this problem would be breakage of the wires in the power cord at the point of entry to the vacuum cleaner body. With the power connected you may be able to prove this by flexing the cord at this point, particularly by pushing the cord toward the body of the vacuum cleaner. If you get any signs of life from the vacuum cleaner you can know that this is the issue (not a foolproof test, but one that can be performed safely, provided that there is no visible damage to the lead).
A qualified repairer will ensure that the vacuum cleaner is not plugged in to the power, open the vacuum cleaner casing, note the wiring connections, disconnect the wiring and and strip the external sheath of the cable back to a point beyond the breakage, cutting off the damaged section of wiring and reconnecting the wires.
See also: http://www.vision6.com.au/em/message/email/view.php?id=638671&u=19329
Apr 05, 2010 | Vacuums
No power
Mar 10, 2010 | Numatic Henry Bagged Canister Vacuum
Hoover Steam Cleaner F6024-900 does not turn on when plugged in to working outlet.
You may have something simple like a bad plug end piece on the power cord. try it in another socket if it still doesnt work you may have to replace the plug.
The most stressed point on a vacume is on the power plug and cord because it gets pulled and twisted a lot.
Jul 14, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Vaccum Cleaner
you probably broke the belt so check that. if the mains cord is damaged, you should replace it
Sep 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Vacuum cleaner smell
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=528723
Posted by lcw1 on Apr 20, 2008
Our Hoover Windtunnel has recently started emitting a bad odor when we use it. We recently bought a new house, and the previous owners had dogs, but the carpet was professionally cleaned before we moved in. I have replaced all of the filters and belts to no avail. At this point, I have to remove and rinse off all of the filters after every time I use the vacuum to prevent stinking up the entire house. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Hoover U6616-900 WindTunnel Bagless...
Vacuums Logo
74 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
