Question about Bowflex TreadClimber TC10
One shock pounds when it comes up - Bowflex TreadClimber TC10
How to change rear struts 2002 saturn LS
Raise vehicle.
Remove tire and wheel assy.
Rmove inner wheelhouse liner ,5 bolts.
Remove the shock-to -knuckle bolt and discard.( Go get a new one). This is the bolt on the bottom of the shock.
Remove upper carrier assembly to body bolts ( top two bolts).
Loosen lower carrier assembly to body bolts until the carrier assembly slides out.
Then, using either a rented spring compressor, or get a pro to remove it for you. If you a rental, please please please look on YouTube to see how to use one properly.
Replace any worn out rubber components, they are sold separately.
Installation is in reverse order.
Torques: Top of shock absorber ,15 foot pounds
Rear carrier bolts, 40 foot pounds.
Bottom shock to knuckle, 110 foot pounds.
Source: Saturn Technical Service Manual , L Series, 2000-2001
Good Luck !!!
Mar 21, 2015 | Saturn LS Cars & Trucks
Torque spec for front shock absorber upper and lower nuts
Hi Connie, I'm glad to help. The front Shocks on your Grand Cherokee are: 26 Foot Pounds on the upper. 250 inch pounds on the lower. Hope this helps and have an awesome day Connie.
Dec 18, 2013 | 2000 Jeep Grand Cherokee Laredo
Whirlpool design 2000 is imbalanced eery load - moves around violently, makes pounding noises.
Thanks for choosing FixYa and welcome. You need to check the suspension of the washer and make sure everything is intact. Now, if the washer is thumping during spinning, this is probably the motor drive or the spin bearing. This would cause a lot of noise. Your washer will act up if it is not balanced right. Check the floor and make sure it is level. If that checks out, look into the motor drive and bearings. The motor drive controls the spinning.
Apr 28, 2011 | Whirlpool Washing Machines
How much air should the rear air shock have in it
It depends on the load on the bike. Unless they've changed something, Harley recommends on air for a single rider. Rider with passenger, 5 pounds. Rider, passenger, and maximum recommended luggage, 10 pounds. You use a special hand pump available at your local dealer.
Good Luck
Steve
Oct 24, 2010 | 2008 Harley Davidson FLHX Street Glide
I have a early 1980's honda 750 need to know how much air pressure the fork's hold, or need to put in them.
You do not have to put any air in the forks. There was a sticker telling you maximum pressure on the bike. It may still be there. Maximum pressure is not more than 14 pounds. You will never need more than 7 or 8 pounds. First set the rear shocks for a hard or soft ride. Then holding a bicycle foot pump with a pressure gauge on it in your hands , give it one pump (do not go over 10 or 12 pounds pressure). Now bounce on the seat and bleed pressure out of the forks until the front and rear shocks drop at the same time. Your bike suspension is now set up correctly for riding.
Sep 26, 2010 | 1987 Honda VF 750 C Super magna
How much air should be in the front shocks?
too much pressure an yul blow rings in shocks call dealer for proper pressure
Aug 04, 2009 | 1985 Suzuki GSX 550 EF
Air in rear shocks
Depending on your weight and if you carry a passenger as to the air pressure. I normally run about 14 but 24 if riding 2 up.
Recommended pressures:
up to 150 lbs- 0
each addition 25 rider pounds > 150 lbs add 1.0 lbs
each additional passenger pounds > 150 lbs add 1.5 lbs
each additional 10 lbs of laggage add 3.0 lbs
Max Pressure 35 psi
Nov 10, 2008 | 2002 Harley Davidson FLHT Electra Glide...
Rear shock replacement
Ummm do you have the spring compressor attached?
If not, put the bolts back in before someone gets hurt.
Those are strut style.
The proper way to remove them is to install the spring compressor, compress the springs a little, then remove the bolts. Then you will be able to remove the assembly, remove the shocks, put the new ones in, and reinstall.
With out the spring compressor, the spring can "jump out" and possibly cause serious injury. That is a 1,000+ pound spring.
Oct 19, 2008 | 1992 Acura Integra Hatchback
Shock absorber
kyb shocks ar the best thats all we use also check the "ruber" on the top make sure it is compresed together any gaps cause the " bump or pounding" noise
Sep 18, 2008 | 1997 Chevrolet Suburban
Bowflex TreadClimber TC10 Logo
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
