I have a Sony STR-DE945 Receiver with no sound coming out. During troubleshooting, I found two bad output transistors which I replaced. I also added jumper wires between the display board, power board, muting board, and volume control board to bypass the failing connectors. Everything seems to power up fine, I hear the output relays click, but no sound. Even the built-in diagnostics tests from the service manual pass. I also checked the +/-15V and 5V supplies to all of the boards. Any ideas what to try next?
  • 30 Answers
I had a similar problem with my denon AV amp all it was were 2 little resistors but I had to scan through a lot as it was after the power supply and in the main bd
Posted on Feb 15, 2014
2 Suggested Answers
electrotech1
  • 1126 Answers
SOURCE: I am troubleshooting a HTR-5830
Check for shorted out put transistors that is pulling your voltage down.
Posted on Dec 22, 2010
I have a sony STR-DE945, and no sound was put out unless you pushed in the power button slightly. Now no sound comes out no matter what. Was going to replace the circuit board part no. 1-676-999-1 but part...
unfortunately, electronics go obsolete very quickly, and the cost to repair a specific unit is so close to that of purchasing a new replacement that very few places stock parts or do repairs these days.
Unless electronics repair is a passion or hobby of yours, you will spend much time and effort trying to get parts, time trying to replace the defective parts (a waste of time and money if you aren't absolutely certain which parts are bad).
Since the complete board is no longer available, troubleshoot to the compnent level and replace the individual items on the defective board, or just get a new receiver.
Aug 11, 2014 | Sony STR-DE945 Receiver
Can I get digital output through my STR-DE945,
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE945-Receivers-manual/id/387dj982/t/2/
The far left optical connector on the back is an output.
Feb 21, 2011 | Sony STR-DE945 Receiver
Please tell me how to remove the fan from the receiver it has stopped working causing the unit to go into a Protect-Fan mode thanx for any help John
hello the reason the fan has stop working may be down to the output transistor shorted out or a swelled capacitor
regards
shaun
Sep 12, 2010 | Sony STR-DE945 Receiver
I have a sony STR-de135 receiver whlie looking for one problem created another.While the receiver was unpluged I touched and output transistor MN2488 and it sparked now the left channel sounds distorted so...
The capicitors in the unit are charged. Replacing the output transistor(s) is not a task for a novist. Capicitors, resistors, driver transistors and sometime preamp chips can also be bad as well. If all the bad components are not replaced the parts you replace could blow out again.
Jun 19, 2010 | Sony STR-DE135 Receiver
How to verify which transistor is creating protection mode?
Take your ohm meter and measure the outputs one by one. with the power unplugged and the main board flipped to access this circuit. If they all check the same , no shorts , then You may have a preamp driver failure. Larry's Electronics ledstiles@hotmail,com
Apr 25, 2010 | Sony STR-DE945 Receiver
Have a str-de 945,unit was working,sound stopped,still powers up.Replaced 2, 8 a fuses,blew again,nothing was connected to the unit.The heavy power supply unit in the front seems to have a hard orange...
Chances are you have shorted output transistors,check with ohm meter across all 3 legs,there should be no shorts if good.. cost on average around 150.00
Apr 16, 2010 | Sony STR-DE945 Receiver
Sony Str-DE945 5.1 not Powering Up all !
It's possible there are several bad solder joints on the front panel PC Board which can cause non responding controls, loss of sound. I repaired mine that way. Try turning it on with remote, see if that works.
Oct 21, 2008 | Sony STR-DE945 Receiver
STR-DE945 stuck in auto protect mode?. I'm pretty sure it is the output capacitors but I do not Know where they are located to change them.
First of all my STR-DE845 started having the protector problem about 6 months ago and I bought this receiver back in 2001. This is what I found wrong with mine. After searching online I found a service manual for the receiver, this came in handy when diagnosing the problem. The first obvious thing was discoloration of the board around the IC 501, 601, and 701 Op-amps. When looking at the receiver from the front these are the three vertical NEC ICs to the right of the main amplifiers. Even with no load these amps get very warm. Sony failed to add any heat sink to these ICs so eventually they can de-solder themselves, specifically the 701 IC which is the one closest to the back of the unit. With mine I was able to slightly push the 701 more vertical, since it was leaning, and I believe it has helped it make a better contact. The protector circuit will kick in if it senses the Op-amps are shorted or not making contact. The best solution is to add some copper heat sink to these ICs, they already have screw slots for a heat sink. If they ever fail you will have to get new op-amps and re-solder them to the board. Hope this helps.
Jan 17, 2008 | Sony STR-DE845 Receiver
 Grubhead
Grubhead
