Question about Tascam Audio Players & Recorders
POWERING UP TASCAM DPO 1 FXCD ERROE CODE 12 COMES UP?
ERROE CODE 12 SHUT DOWN SHOWS WHEN POWERING UP
4 Suggested Answers
vanni7
  • 163 Answers
SOURCE: Have new Rinnai R94LSI tankless
Hi!!! you seem to have a bad flame sensor..but you could have so many errors with this heater its unbelievable call rinnai at 1-800-621-9419..good luck..
Posted on Jan 04, 2009
  • 244 Answers
SOURCE: PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Posted on Dec 06, 2009
MECP Guy
  • 344 Answers
SOURCE: FXCD 1100- CD sucks in but won't play-E-7 on screen
E-7 is disc was inserted upsidedown
Posted on Apr 26, 2010
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
I have a Tascam DP-01fx/cd that after powering on it reads sreset error :12 please power off. How do I fix this so I can use the machine again?
Jan 02, 2010 | Tascam DP01 All-In-One Recording Package...
My 2488 worked fine for over one Year now i don't have anny Fader control everything is playing over my Earphones is there a factory reset ?
I reinitialized the Unit 2488MK2to the factory settings.Simultaneouly hold down
the Quick Routing,Shift, Send and Shut Down buttons with all the buttons pressed-------
turn the 2488MK2 on. the first 3 buttons you can do with one hand the shut down button wich is close to the on & off swich with the other hand the Trick is hold the buttons down until the dispay
shows unit is factory recett shut off your 2488MK.
Mar 27, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 locked up/frozen
This will reinitialize it to the factory settings. All data (music) will be lost.
With the 2488 turned OFF
Simultaneouly, hold down the Quick Routing, Shift, Send and Shut Down buttons.
With all buttons pressed .... turn the 2488 ON.
It shoulld go through the normal boot up screens, including a screen that states ' partitioning drive', etc. When finished it will show ' Factory Settings Reinitialized - Reboot (or something like that) and you are done.
I have the original 2488 as well, and tried everything recommended to address the HDD lockups.
I think I know why Tascam eliminated the Tone Generator (Drums) on the MKII and Neo versions.
Too much for the processor to handle?? Hope this helps.
Bill H
Mar 24, 2009 | Tascam 2488 Portastudio Multitrack...
Removal of installed FXCD-500 from car?
the keys go either side of the CD plater, you should see little slots, either in the trim ring or behind it, just slide them down the side.
you then have to push the keys outwards i.e 1 towards the driving wheel and the other towards the glove box.
at the same time pull stright out!
Please rate
Hope this helps
Feb 17, 2009 | Sanyo FXCD-500 RB CD/Cassette Receiver...
Sound module & mic (connected to a Tascam US-224) not working
I may be able to help.  I am a longtime Mac and Tascam control surface user.  I am currently running a MacBook Core 2 Duo 2.0GHz running OS 10.5.6 with a Tascam FW-1884 audio interface/mixer/control surface connected.
Setup is fairly easy in the Mac OS.  Here are the steps I'd follow:
NOTE: Before beginning the following process make sure that ALL of your MIDI gear is connected.
- Tascam connected to USB port of computer
- MIDI Keyboard "OUT" connected to Tascam "IN"
- Roland "IN" connected to Tascam "OUT"
1) Open your "Applications" folder.
2) Open the "Utilities" folder.
3) Double-click on "Audio MIDI Setup."
4) At the top of the window select "MIDI Devices"
5) In the pull-down menu on the left select "New Configuration."
6) Title your configuration and press "OK"
7) If your gear has been detected automatically their names and icons should appear in the main window.  If so, skip down to step 12
8) Click on the "Add Device" button
9) Double-click on the "new external device" button that has now been created.
10) Select your device's manufacturer and model (i.e. Roland, JV-1010).
11) Adjust any other settings appropriate to your setup.
[In the main window there should be a Tascam US-224 button.  On it there should be one pair of arrows that indicate the MIDI In and MIDI Out ports of the device.]
12) Click (and hold) on the MIDI Out arrow of the US-224 button.
13) Drag the "cord" and attach it to the MIDI In of the Roland JV-1010 button.
13) Click (and hold) on the MIDI In arrow of the US-224 button.
14) Drag the "cord" and attach it to the MIDI Out of the "keyboard" button.
This should get you setup from a Mac OS/Device routing perspective.  For the appropriate US-224 Control Panel settings refer to the User Manual.
Feb 07, 2009 | Tascam US-224 DIGITAL AUDIO WORK STATION...
My Tascam DR-1 digital recorder will not turn on
To initialise the Tascam DR-05:
Press and hold the + button and the Mark button while turning on.
Thanks
Feb 03, 2009 | Tascam DR-1 MP3 Player
Error Message on copier.
Probably a thermistor problem, dirty or out of position or failed. Could be thermostat too.You will want to check that fuser out first before you reset any codes. Checking for paper, sensors, etc...
If all is clear in the fuser then:
With the power off, hold the 2 and 5 button on the panel and turn the power on. In the display you will see, there are 1-12 choices, choose 1, Software SW. You will see a display of numbers (01-0:1 03). Change the first number to 03, change the second number to 01, change the third number to 00. Press RETURN on the display. Power the unit off, then on. Codes should be reset.
If after resetting the code and powering up machine -- if code comes back then replace the above mentioned.
Jan 23, 2009 | Office Equipment & Supplies
Have new Rinnai R94LSI tankless water heater during startup the burner wll come on for about 1-2sec.then stop and gives me a erroe code 12.
Jan 04, 2009 | Heating & Cooling
27 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
