Question about Tablets & eReaders
Mid tablet black screen
Tablet has black screen. I tried the flashlight thing, I tried holding down the volume keys and it is solid black. No screen whatsoever, no logo nothing... Just the green light from the power button comes on. Any ideas would be much appreciated.
  • 53 Answers
I think its battery has been dead try to replace the battery.
Posted on Feb 15, 2014
dugiehowsa
  • 114 Answers
SOURCE: Do I need a battery to run the PC Tablet?
THe manual for your specific model can be found here: http://support.fujitsu-siemens.com/Manuals/ShowDescription_KMT.asp?DokuID=202607 Documents for othe models and languages can be found here: http://support.fujitsu-siemens.com/com/support/manuals.html
Posted on Sep 25, 2006
SOURCE: Intuos3 Tablet's pen is not working
Try reinstalling the software that came with the tablet.
Posted on Jan 07, 2010
agc93
  • 44 Answers
SOURCE: While playing a game, my
If holding down the power button for 10 seconds (theoretically, try holding it down for ages and be patient) doesn't reset your device, you may have to wait for the battery to run flat, then try the reset procedure again.
Hope this helps, Alistair
Posted on Mar 15, 2011
SOURCE: my tablet is showing the
Mine did the same thing, son told me to hold the power, home button and volume up button for about 10 second and it would reboot, which worked for me.
Posted on Aug 26, 2011
  • 102366 Answers
SOURCE: user manual for 7" mid tablet pc
User Manual
Quick Setup Guide
Posted on Dec 30, 2011
My tablet wont come on. whenever i turn it on it just comes to the loading screen and says system loading. then it wont go any further its stuck on the loading screen. what's wrong it?
Sounds like a previous update did not finish installing due to being switched off in mid stream or it got corrupted.good news is you can reset android tablets to factory settings...bad news is you will lose all you settings and apps which you will need to reinstall once it is up and running.most tablets reset in the same way.
switch off ...then whilst holding the up volume and the home button hold down the power button then continue holding just the vol up and home button.it will display the robot then you can let go of all the keys and follow on screen instructions to reinstall factory reset.
some tablets are a little bit different to reset...instead of volume up its volume down.if you google your make and model of tablet it will describe correct procedure...one last thing...do not panic if it doesn't reset first time...some Chinese based tablets may take two or three attempts to reset.
Jun 11, 2015 | Tablets & eReaders
How do i fix my hp tablet stream7 that has a black screan
You can try a factory reset, try holding the power button and the volume down key on the side of the tablet then use the up and down voulum keys to select factory reset and push the power button. That should bring up a screen that says are you sure? Use the volume keys to select yes and it should reset. If this doesnt work, you have to get ahold of hp customer service.
Jan 25, 2015 | HP Tablets & eReaders
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
How to restart my tablet without turning it on because I forgot my password?
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
Jan 03, 2015 | Tagital Taital TM 7" Android 4.0 4B MID...
How do I reset my Tablet. I forgot the password.
- Turn the tablet off
- While holding Volume Down, press and hold the Power button
- Use the Volume Up and Down keys to highlight Factory Reset
- Press the Power button to select to reset
Oct 29, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
I have a klu by Curtis LT -1041-c screen went black can't get it to come back on.help tablet.
1. Make sure tablet is off.
2. Press and hold the "Volume Down" key and 'Power' key
3. When "Klu by Curtis" splash screen shows release the power key
4. A laying down android with cover open and a red triangle with an exclamation point will appear.
5. Rock the 'Volume Down' and 'Volume Up' and press the 'Power' keys to dislplay the BIOS screen.
6. Use the 'Volume Up/Down' keys to navigate choices (wipe data/factory reset) and the 'Power' key to select the choice.
7. The following screen will ask you to confirm your choice and warn you that this cannot be undone. Repeate step 6 to select your choice.
8. When wiping all data is complete, select 'reboot system now' to restart tablet.
Done!
Oct 07, 2014 | Tablets & eReaders
How do I do a factory reset on my certified mid-73005 tablet
  1. Press and hold Power button to turn off your tablet.
  2. Press and hold Volume Up and Power buttons at the same time for about 10 seconds.
  3. Once see the menu, select wipe data / Factory reset. (Use Volume keys to scroll up/down. Use Power button to select)
  4. It will take about 2-3 minutes to reset.
  5. Then your tablet will boot in.
  6. Set up and use as normal.
Sep 29, 2014 | Tablets & eReaders
Mid tablet forgot password
Power on the phone and hold the VOLUME DOWN and UP button, and then hold the POWER button.
Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Aug 01, 2014 | CHINA DIRECT 7 Inch Android Tablet with...
Froze on black screen that says android have tried holding down power and volume still froze
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Feb 23, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Unlock dot pattern lock android
Normal way for Android is to power down and then hold the power button and the volume Up button.
Way 2 is to hold power, vol up and vol down.
You have to hold until the recovery console appears, so about 20 seconds.
Only a few have a reset button inside a hole.
However, yours is different to all the rest :>)
Just completed this procedure and repeated to confirm: Klu by Curtis 7035-j
2. Press and hold the "Volume Down" key and `Power` key
3. When "Klu by Curtis" splash screen shows release the power key 4. A laying down android with cover open and a red triangle with an exclamation point will appear.
5. Rock the `Volume Down` and `Volume Up` and press the `Power` keys to dislplay the BIOS screen.
6. Use the `Volume Up/Down` keys to navigate choices (wipe data/factory reset) and the `Power` key to select the choice.
8. When wiping all data is complete, select `reboot system now` to restart tablet. Done!
Read more: How to perform a factory reset on a Curtis Klu LT7035-J tablet? - How to perform a factory reset on a curtis klu lt7035 j tablet :: Ask Me Fast at http://www.askmefast.com/How_to_perform_a_factory_reset_on_a_Curtis_Klu_LT7035J_tablet-qna6954204.html#q6015781
Curtis Klu 7 inch Touch Screen Google Search
Apr 23, 2017 | Curtis Klu 7-inch Touch Screen Mobile...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
