Question about Acer Aspire 5100 Notebook
Black screen just replaced my motherboard and still have the dredid black screen. What should I do next? do I still need to flash the bios? if so how do i go about that
    Top Expert:
  • Acer Master
  • 22,766 Answers
With the laptop ready to go, try an external screen. That will tell you where the issue is.
Posted on Feb 15, 2014
I have hp pavillion DV6-6c35dx black screen with caps lock blinking twice to indicate corrupted bios. How do I flash the bios on this laptop?
If that computer wont boot to a screen that you can recognize, it is a brick. When the bios is corrupted and it wont allow the machine to start you cannot access any screens that will allow you to recover. It takes special equipment to flash the BIOS when this happens and most places just replace the whole motherboard because this equipment is not used often by repair shops.
Dec 14, 2016 | HP Computers & Internet
Black screen flash bios
You don't need to access the BIOS to format your laptop. Put the Windows disk in the optical drive and then select format when you reach the correct prompt.
May 06, 2013 | Gateway Computers & Internet
I need to update my bios
Updating bios just for the sake of it is a dangerous practice. If your system is not having any problems then leave it alone. If you do have problems such as inability to recognize a larger harddrive or incompatibility with a particular newer piece of hardware such as NIC or modem etc, and the maker's website indicates a bios update is available to address the problem then you should consider the risks/benefits. If a bios flash goes wrong you can completely trash your motherboard.
If you still want to proceed with this exercise then start by downloading Everest Home Edition from lavalys.com. Instal and run it and it will give you info on your system components including motherboard model and bios version. Once you have that info you should carefully research bios updates from the motherboard manufacturer. Flashing the bios is done using a bootfloppy that has to contain both the flash utility and new bios file. If any power failure or surge or error occurrs during the flash process, you're toast. The motherboard may or may not have a jumper that needs to be moved to "Unprotect" the bios so that you can perform the flash.
You will also be given an opportunity to save a backup of the original bios. Do so. If the new bios doesn't work properly you should be able to re-flash back to the old version.
I repeat. Unless your system has a problem that can only be resolved by a bios update then DON'T DO IT.
Another solution
Determinine Your Current BIOS Version
You can find your motherboard's BIOS version number on the POST screen. Restart your computer. As soon as you see the Biostar bootup splash screen, press TAB, this will reveal the POST screen (if you don't see the splash screen at all, it is okay. The version of BIOS you have most likely doesn't have the splash screen). Then immediately press PAUSE/BREAK key to suspend the boot process. You will see a screen similar to the one below:
post_sml.jpg In this example, the BIOS version is VIT0312F.
VIT = Model number
0312 = BIOS date
F = No splash screen
three_bluedots.gif Updating BIOS
All modern Biostar motherboards feature the Flasher technology for easy BIOS updating. If you have a legacy board, please download the Award flashing utility and follow the instructions in the README.TXT file instead. The procedure below does not apply to legacy boards.
Most motherboards' BIOS files have the BIN extension. Some do not (for instance, NCD1208.BSP, NHA0302.BF, etc). Regardless of its extension, after downloading the BIOS file is ready to use as-is. You do not need to do any kind of decompression or extraction.
Download the BIOS file (in this case, VIT0312B.BIN) then save it to a floppy disk. Restart your computer. Enter the CMOS setup by pressing at the POST or Biostar splash screen. Make sure the disk is in your floppy drive, choose "Upgrade BIOS" from the CMOS Setup main menu. The Flasher utility will automatically detect and highlight the BIOS file (in this example, VIT0312B.BIN) on the next screen.
Make sure the BIOS file (in this case VIT0312B.BIN) is highlighted and press Enter. Answer Y when prompted "Are you sure to flash?". After the flashing is done, reset the computer and enter CMOS setup again. This time choose "Load Optimized Defaults" from the main menu. Finally, hit F10 to save and exit.
BIOS update is complete.
three_bluedots.gif Legacy Motherboards
If you have a legacy motherboard which does not support the Flasher technology, please download the Award BIOS flashing utility and follow the instructions in the README.TXT file.
Aug 07, 2011 | Computers & Internet
I was traing to flash my bios on MB GA-7VA and fail !!!
> is there some way to put new BIOS?
Yes -- details are on Gigabyte's web-site.
> Is BIOS chip removable?
Yes -- but you'll need special hardware, a "ROM programmer" to load a new BIOS onto the chip.
Jan 20, 2010 | Intel Motherboard
MY LAPTOP WENT BLACK AFTER I SPILLED SOMETHING ON
Its better to show it to technician bcz it seems the motherboard inside lost bios flash and its unable to detect old settings so that everytime it reboots checks bios and then reboots again to flash it. Better show it to a local technician. One other way is to try booting it in safe mode and then check if it works.
Oct 29, 2009 | Compaq Presario Notebook
Interrupted flashing bios screen is black. hard
Your motherboard is now fried-- good job you will have to replace.
Sep 22, 2009 | Compaq Computers & Internet
HOW CAN I RESET THE BIOS ON M7VIZ MOTHERBOARD?  There is no video and this is the last thing I know to do.  I took the video card out and plugged in to the onboard video, I have tried a new video card and...
You mean reset the CMOS? There may be a jumper to go back to factory defauts. Flashing the BIOS is not what you want to do at this point. Get out your motherboard manual and look for a jumper on the board to reset the CMOS.
Mar 17, 2009 | AMD BOSTAR M7ViZ Socket A Motherboard...
Boot up problem
Sounds as if you need to change your cmos battery (Cr2032 on motherboard) first of all as i'ts a very cheap item to replace, then set the bios up again, then try to boot, if still no boot you may need an operating system repair.
Sep 28, 2007 | EPoX EP-9NPA3 Ultra (EP9NAPA3ULTRA)...
Badly flashed bios
i can fix that if only you are in my country(Philippines)
Sep 22, 2007 | Abit AB9 Pro Motherboard
Acer Aspire 5100 Notebook Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
