Question about Jenn-Air Refrigerators
I need the exact dimensions of jennifer-air model jrt236 refrigerator
I need to know the cubic feet of my Kenmore Refrigerator model 795.7101 purchased 12/2010?
measure the internal dimensions ( width X height X depth and that will be the cubic feet capacity of the unit
while you answer may not be exact to what the manufacturers state , it will indicate the advertised size of the unit
Nov 11, 2015 | Kenmore Refrigerators
I just bought an 08 Chevy Malibu.. It has been sitting for 6 months. Two days after I bought the car the check engine light came on. I took it to three mechanics and the code p0113 came up. The in take air...
Hi Jennifer ,
I think i just have the exact thing you want ! :) ... please check the tutorial video I am sharing ... and if it helps leave me a feedback.
Thanks, Vijay
Jan 02, 2015 | 2008 Chevrolet Malibu
Ariston instruction manual
A bit hard to come up with dimensions or user instruction manual without knowing the refrigerator type or model number.
Please visit this Aristron website and select the model number listed to download the user manual or check the dimensions. Cooking Appliances Kitchen Appliances Dishwashers Download Manuals
Aug 29, 2014 | Refrigerators
Need to replace door gaskets
Emmie,
There are two gasket options for that model! If you have your unit's serial # we can ID the exact gasket you need. Replacing your gasket is a simple process and it looks that your gasket is a simple snap in option. Here's option1 http://www.coolergaskets.com/turbo-air-gasket-25-1-2-x-53-1-4-1/ & Here's option 2 http://www.coolergaskets.com/turbo-air-gasket-25-1-4-x-53-1-4/
It looks like both gasket options are made out of the same profile material but the dimensions changed per when the unit was manufactured. Double check your existing gasket's dimensions to determine which option is the best for you. Or shoot us an email or give us a call with your Model and Serial # and we can narrow it down for you.
855-288-2259
orders@coolergaskets.com
Aug 03, 2012 | Turbo Air TSR-49SD Stainless Steel...
I just need the specifications/dimensions of my Kenmore Elite Refrigerator, model #106.54609300. I need a new fridge of similar size to fit in an enclosed space. I have searched all over the web and...
I have this exact model. Here are the specs:
depth: 30"
height: 68.5". with hinge: 69.5"
width: 35.5"
15.5 cubic feet in the refrigerator section
10.0 cubic feet in the freezer section
25.5 cu ft total
Sep 08, 2011 | Kenmore Refrigerators
What is the cubic feet measurement for a GE Model TBX18 refrigerator? Also, what is its width and height?
The capacity depends on the exact model number. The TBX18TABWW and similar models are 17.6 cu. ft. The refrigerator holds 13.6 cu. ft. and the freezer 4 cu. ft. This model is 64.25" tall, including the hinge, 28" wide, and 31.25" deep.
The GE S series, including
TBX18SIBRWW, are 18.2 cubic feet; the specs are 13.04 cu. ft. for the fridge and 5.13 for the freezer. Total height (including the hinge is) 64.75", 29.375" wide and 31.5" deep including the handle. (It takes up 58" with the door open.)
The J series has the same total capacity and dimensions as the S series.
Remember to leave 0.75" free on both sides and 1" at the back and top for air to circulate around the refrigerator.
You can find your exact models specs and manuals here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box and click submit. Dimensions are provided in the Quick Specs for most refrigerators. The model number will be on a plaque in any of the following spots:
1) On the ceiling of the freezer near the front
2) By the temperature control
3) On the inside wall of the refrigerator near the crisper drawer on either side
4) Behind the crisper drawer
5) On the bottom front of the refrigerator
I hope this helps.
Mar 18, 2011 | Refrigerators
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
