Screen on Gateway FPD2185 stays black.
Screen is black. "VGA Input" flashes on screen momentarily when fired up. Power light stays'ON'. Display can be seen faintly with a flashlight shone on screen. Voltages to logic board look good. Electrolytic caps have already been replaced. Polarities are correct-I did it myself.
  • Computers & ... Master
  • 15,628 Answers
The back light is out. Might be the inverter or the tube.
Posted on Feb 15, 2014
Testimonial: "This is a non-answer. Of course it is either the inverter or the backlight. "Might be" is never a solution."
  • Brad Brown Feb 15, 2014
    Ok, unless you have a high frequency VOM or oscilloscope, then you would not be able to test the inverter so a shop has an advantage for that reason or they can swap inverters to see if it is that or the tube, it is a process of elimination on their part. The only sign that it might be the back light tube is if the display was tinted orange before it went dark. It is cheaper to get the inverter than it would be the back light tubes.
SOURCE: Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Posted on Feb 06, 2008
Sid869
  • 12 Answers
SOURCE: With VGA input the screen randomly flashes on and off
power control chip of the VGA input screen is not controling the input settings
Posted on Jun 29, 2009
SOURCE: Samsung Sync Master 914 has no picture. When
I would check the caps with ohm meter. Make sure they all show increasing resistance. Caps can be bad without looking bad. Check output voltage on the power board, should be around 12V. If all that checks out then I'd look next at the backlight bulb. I'v repaired many monitors and the problem was almost always overheated caps on the power board. Post back and let me know.
Posted on Dec 03, 2009
Testimonial: "Amazingly fast and helpful response. Follow-up help needed and posted as a comment."
  • 164 Answers
SOURCE: Monitor flashes on but with 1-3 seconds it goes to
Try different video and/or power cables, but most likely this is dead. Sorry!
If it's still under warranty, (or the computer it came with is), call Gateway support.
Posted on Mar 10, 2010
  • 732 Answers
SOURCE: My Samsung SyncMaster T220 does not display
m_r_murphy, The T220 may have developed an internal ac to dc "switch-mode-power-supply / CCFL inverter supply" power problem an you may need to need to have it repaired, Look into warranty or outside technician to refurbish the unit's SMPS/inverter!!! From your description, I believe that the SMPS is in "partial shutdown" mode!!! (no 12 to 14v dc) to power-up the "cold-cathode-fluorescent-lamps" that enable you to see the text and graphics that you already know are being displayed on your lcd panel!!! (+5vdc or 3.3vdc rail still alive!!!) You have "black screen" symptom!!! NOT BLANK n BLACK screen!!! There are lots of DIY videos on YOUTUBE to help you decide if you can attempt a cheap (<$20usd) repair to your unit. Do some reading in my old fixya profile (louie12fix) and visit some of the links you find there. Because your T220 isn't any different than any other brand of CCFL back-lit lcd display in it's basic design and operation you should be able to fix it. Get back to me lmistyrel on aim or do additional comment to this original post here on fixya with info on your next step to repair this unit.
All the other ccfl back-lit lcd monitor tech's on fixya already know what's wrong inside your unit!! Do your research first!! Bye for now, 12fixlouie
Posted on May 07, 2010
LG 37LG30 wont come on. Gives blue light, but screen stays black and no sound
Sounds like the problem could be in the power supply of the TV. Have a technican check for defective capacitors if you're not equipped to do the job yourself.
Apr 22, 2013 | LG 37LG30 37 in. LCD HDTV
Have a Gateway Notebook KAV-60 with a broken screen. Trying to connect to an external monitor without any prompts or commands, as I can't see the screen. With an Acer Netbook I just plugged in the
Make sure the vga cable is in tight on the kav-60 and the external monitor.
Try the keystrokes to toggle the display. Normally you would Press and Hold the FN function key located at the lower left on the keyboard then hit the key F1 thru F12 that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display. The display toggles in three stages ( laptop only, external only or both laptop and external).
Apr 29, 2012 | Gateway Computers & Internet
Gateway 5150 - computer screen stays black, screen works fine, just very very dark - can't seem to adjust luminosity?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 09, 2012 | Computers & Internet
I have Gateway NX560XL Laptop. Work fine. Next time tried to use it , it comes on fans run and all, but screen Never comes on. Has harddrive gone bad?? Do i need a new laptop??? I have tried every...
Your screen may have gone out - try hooking up an external monitor with a VGA input. Connect it to the VGA output of the laptop. If you get a display, your screen inverter or backlight has gone out. If the hard drive light on the control panel is flashing then the harddrive is likely ok.
Oct 28, 2010 | Gateway NX560XL PC Notebook
I turned on my m-675 yesterday and got the gateway green and black screen that just continued to stay there. After 5 minutes I used the control/alt/delete buttons to reboot my computer. Now, my computer...
From the information, that you used control/alt/delete to re-boot, I am assuming that you sensed that the computer finished the booting process. Meaning the tell tale sound (music) of windows booting was there, the hard disk whirling (blinking LED) for a certain period and stopping etc. If that is the case, (meaning you think your computer is capable of booting) probably you have a display failure. If you have a VGA cable connect that cable to the VGA connector (0n your laptop) and connect the other end to Desktop screen (monitor) or a TV screen with a VGA input. Probably you will see a display right away. If not press the Fn key and the key which changes the screen from laptop to external screen. This key will be marked either as CRT/LCD or with a picture( a square with two lines on either side of the square). If you get a display there, you may need to get a technician to change the screen.
Feb 11, 2010 | Gateway M675 Notebook
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
Gateway FPD1530 Backlight turns on, but no display
has to do with power i can get myin to stay some times but then the same thing hapens to me u have to buy a new power board wich is esy to replace and i have had min as a second screen for like 4 or 5 years now with no probloms so its just from over use..
Jul 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway Monitor Power Supply Problem
I have the same problem. I just unplug it and reconnect. The display comes back. I have no idea why this is happening.
H
Jun 25, 2009 | Computers & Internet
Screen only stays on for 1 sec
Assuming you changed all the caps and did it correctly.
IF you get flickering, It could be a transistor on the inverter board.
OR !!! and probably more likely,
It could be one of the bulbs in the lcd itself is failing. It only takes one bad bulb to stop an inverter from firing up !! You can check them one at a time if you have another working monitor.
If you do unplug a good bulb from the good monitor and try each of the questionable ones, one at a time.
Doesn't have to be a gateway monitor to test it, just needs the same backlight plug.
ebays bammbammfran
Jun 05, 2008 | Gateway FPD2185W 21 in. LCD Television
Computers & Internet Logo
David Payne
David Payne
