Question about Scotch 9" Tl901 Hot Laminating Machine / Laminator
I pligged my laminator in and it made a popping sound and no longer turns on
  • Kathy Millets
    Kathy Millets Feb 15, 2014
    Hi Kathy Millets, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Kathy Millets
    I have used this laminator a few times without incident. However, after plugging it in it made a loud popping sound and no longer turns on.
CSl laminator 2700 is making a clicking noise
some of these laminators have to warm up. if the laminating strip is burned out it may do what your saying because it is resting and then trying to warm the laminator strip again.
Nov 02, 2017 | Cars & Trucks
The laminating paper started coming out rippled half way through a roll. Do you have any suggestions?
Usually caused by uneven pressure / heat. If this has a lot of use look near ends see if you have small ridge that goes around roll. Would be where edge of paper would be. If you do your pressure roll is worn and no longer provides constant pressure feed.
replace rollers.
Sep 23, 2016 | Gbc HeatSeal Ultima 65 Roll Laminator
Why doesn't our laminator always roll?
It sounds like the control panel switch membrane( under the panel buttons) needs to be replaced. The bad sound may be your heat roller bearings failing. They dry out and start squealing. They also can cause your machine too slow down or stop. There are 2 bearings on either side of the laminator, 4 total.
Sep 08, 2015 | Gbc Heat Seal Ultima 65 Laminator 1710740
Control Panel does not work. When Power Switch is turned on the machine immediately begins running fast.
Sounds like the yellow and the orange wire connectorson the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Aug 26, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
While I'm laminating, the roller stops turning. I have to manually turn it. It works for another foot or so, then stops again.
It sounds like a broken tooth in the roller gear. It advances about the same as the diameter of that roller. Best just replace it.
Apr 16, 2015 | Office Equipment & Supplies
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do i get my Fellowes Venus 125 Laminator 5215901 to stop bleeping and heat up ?
Unfortunately, this message was posted in the section for paper shredders. If you still need an answer you will need to repost it.
Jul 16, 2014 | Fellowes Venus 125 Laminator 5215901
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Can I install laminated floor in my bathroom?
Laminated floors can be used in any room you would like although there are some laminated floors that are more sensitive to moisture. If you want to use laminated floor in your bathroom you will need to prevent water from core material of the floor.
Feb 06, 2013 | Building Materials
Instructions and /or tool for removing generator winding from motor shaft.
The rotor is attached to the crankshaft by means of a tapered shaft. Believe it or not the best way to remove it is to beat on the metal laminations with a plastic dead blow hammer. Hit one side a couple oof times then turn the rotor 180 degrees and hit a couple of times. Keep repeating this until it pops off. Be careful not to hit slp rings, windings, etc... just the metal laminations. You will not hurt. them.
Mar 22, 2009 | Electrical Supplies
Scotch 9" Tl901 Hot Laminating Machine / Laminator Logo
71 people viewed this question
Top Scotch Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Scotch Office Equipment and Supply Expert? Answer questions, earn points and help others
