Need manual for temp rite 10 # s481u - Heating & Cooling
How to fix error code 6 on a sta-rite pool heater?
Try replacing the Temp sensor. You can not just jump it out, it needs to be repaced.
May 28, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
My sta rite pump just shut off on its own in the
need more info is motor hot when it turns off if so the temp over heat circuit is turning it off may need new motor
Sep 20, 2013 | Pool & Spa
Ref: Sta-Rite Max-E 400. Pool temp is about 75
Your temp sensor has gone bad and will need to be replaced. It's a small tube that slides into the water manifold and you can follow the wires back to the board. Just unplug and set a new one in place.
May 12, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Apr 04, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Heater won't maintain program high temperature
Not sure which one is correct but here is a link to the Pentair/sta-rite site so you can get the information.
Sta-rite Heaters
Feb 22, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
