Question about Video Game Consoles & Games
Playstation2 repair I am able to turn on my PS2, the first time it brought me to the main menu of the game, then let me load my saved file and I was able to play. However, it froze, then when I tried to re-set and put the game in, it would let me get to the main menu, load, but then go to a black screen - this happens with more than one game. It is still in great shape and discs are clean, can this problem be fixed, or do I need to replace the system?
  • 78 Answers
SOURCE: disc reading
Replace the lens with a new one.
Posted on Sep 07, 2007
  • 41 Answers
SOURCE: fix ps2 disc game and go faster to load.
its a ps2 problem open the ps2 up if its a big ps2 not a mini and dust it the dust is making it harder for your ps2 to read disks open it dust it and itll be like barnd new if its a small ps2 i dont know dusting the thing always help dust with somthing small a cotton ball or ear swab will work
Posted on Jan 01, 2008
  • 52 Answers
SOURCE: I have recently purchased a
The Fifa 08 game has problems if you are not using a "HD" output. So if you don't have a Hi-def TV then don't buy this game (It is why i didn't buy the PS3)! I am not sure about the other game.
Posted on Jul 08, 2008
  • 273 Answers
SOURCE: Goes to Startup Screen when I put a game!
try cleaning the lens. for a slimline PS2, try a Q-tip with a little bit of alcohol on it and lightly touch the lens. gently TWIRL the Q-tip. use the other end of the Q-tip to dry the lens, again, gently twirl the Q-tip. or you could use a laser lens cleaner (see below). for a fat PS2, either use a laser lens cleaner specifically for video game systems (Best Buy, etc.) or go here and go to the very end. www.powerfulguides.com/ps2 hope this helps :D
Posted on Jun 10, 2009
SOURCE: When I insert a PS2 disc and power on the
Check to see if the top lid is closed correctly. Probably one of the small locks on front of it has broken off and the Playstation 2 wont spin the disc. Check to see if they are intact as well. If this is not the problem then you should probably call the PlayStation 2 Support Line, or just call up Sony.
Posted on Sep 08, 2009
Won't accept the disk and grinds
The first is that "Disc Read Errors Diagnosis mode could be the solution.
Load your PS2 without a disc inside and wait until you get to the main menu.
Press Triangle and highlight "Console", then press Triangle again and set "Diagnosis" to ON. What does this setting do? Basically, it focuses the laser on the disc so that it has an easier time reading discs.
In addition, you must turn this setting on EVERY time you load your PS2, as the PS2's system settings are never saved when you turn off your console
Aug 18, 2010 | Sony Playstation 3 (PS3) Console
CAN A PLAYSTATION2 MEM CARD BE RE-USED
yes you can.. just go into the memory card management and delete files. if you have two of the mem card both in your ps2 you can move over save files too.
Jun 03, 2010 | Sony PlayStation 2 (PS2) Console
Need to selct english on the ps2 box itself,its in asain can u help
Remove any disk and close the disk tray. Turn off your system and let it sit for a few seconds before turning it back on. Select the "Language" option from the main menu to open the language menu.
Move the cursor up using the directional pad on your controller until you get to "Language Select." Push the X button repeatedly until it lists "ENGLISH." This changes the audio settings from English to Spanish.
Scroll down to the "Subtitles" option in the language menu and change this setting to Spanish as well. The subtitles will appear in ENGLISH at the bottom of the screen every time a character in the game speaks. If you wish, you can skip this step and rely only on the audio settings.
Press the Circle button on your controller to move back to the main menu, which will save the settings. Select the correct time and date setting for your time zone, if the system asks you to do so. Push the Circle button again to access the main menu.
Place a PS2 game into your console and let the game load. You should now have ENGLISH, settings on your PS2, including subtitles.
May 05, 2010 | Sony PlayStation 2 (PS2) Console
Guitar Hero Metallica Wont play on my Ps2
okay, try this: 1. Start up PS2 with no disc 2. select 'Browser', press triangle. 3. select 'Console', press triangle. 4. select 'Diagnostics', press X, select 'ON'. 5. press 'O' to back out of this menu. 6. select 'Playstation Drive', press triangle. 7. select 'Disc Speed', press X, select 'FAST'. 8. press 'O' to back out of menu. 9. turn off PS2. 10. insert disc. The Diagnostics should run and automatically adjust your PS2 to play the game. I got this "FIX" from someone who had the same problem. Hope this helps :D
Jun 09, 2009 | Sony PlayStation 2 (PS2) Console
Memory Card Corrupted
you cannot save another file until you delete previous one.Corruption occurs if the memory card is removed from console or if you reset the game while saving or loading game remember this also happens when you are saving or loading game and electricity turns off.
May 29, 2009 | Sony PlayStation 2 (PS2) Console
Rock band won't play on my playstation2 slimline
ughh my rock band disc loads the playstation2 screen and when the black is suppose to load it its doesnt go any farther and the playstation makes a beeping sound :( help!
Aug 02, 2008 | Sony PlayStation 2 (PS2) Console
Not playing game
If this is happening to all of your games, then your PS2 will need to be repaired.
Mar 23, 2008 | Sony PlayStation 2 (PS2) Console
PLaystation2
I dun't know, but mine does the same thing! Silver satin right?
try cleaning the lens with a DVD laser cleaner disc, I bouth one at Walgreens for about $12.00 it's Scotch brand, has a few brushes that gently clean the laser, dont touch them tough cause u can get oils from ur fingers on it, if not use a Q-tip with rubbing alcohol, not too wet! and gently in a curcular motion clean the lens! GENTLY! ... if all that don't work, and the game's not scratched, the laser could be bad, I heard that the laser sucks on the PS2!
Oct 13, 2007 | Sony PlayStation 2 (PS2) Console
Playstation card
Your question is somewhat confusing, using a playstation 2 memory card, will have PS2 game saves on it, how would you play PS2 games on a PS1 from the save, you can't. If you just mean you are using a PS2 card for a PS1, the way a PS2 card saves data is different to a PS1 card, so it probably won't work You can use your PS1 memory cards in the PS2. You can only use the PS1 memory cards to save PS1 games that you are playing in your PS2. You can't save any PS2 game data to a PS1 memory card
Oct 05, 2007 | Sony PlayStation (PS) Console
PS2 BROKEN PLEASE HELP
Your Playstation2 lens is weak and you have to replace it with a new one.
Sep 01, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
32 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
