Question about Kenwood VR-309
Surround sound not working properly
I was just given a Kenwood VR-309. I am sure it works fine as it was barely used. I just can't seem to figure out why my surround sound speakers aren't working together. When I am in stereo mode I get my front R and L speakers, but my center and rear don't work. When I switch to ProLogic mode, my center and rear speakers work, but my front ones don't. I can't seem to figure out why this is the case. I am obviously getting sound out of all the speakers, just in different modes and not all at one time. Any ideas?
  • Anonymous Dec 23, 2007
    i hooked allt he speakers up properly and the sound only comes out of the front right and front left speakers what do i need to do
  • bradym Dec 26, 2008
    Same exact problem as toestring's.
Hi guys,
Make sure that your sound aka dvd or whatever is set for a DTS (5.1) set your dvd at bitstreem and your receiver to automatic detection. When your movie will start you will heard your Receiver Relay//Mosfet clicking and a Red led will say DTS once you get there you will be able to select your Doldy digital surround the real one.
Ps: if you want to reset your VR-309 to default HOLD the POWER button for 5 sec unplug it from the wall hold it for 5sec while unplugged and replug it will be rested to default.
Posted on Jan 28, 2009
I need help trying to set up the surround sound for my vr-390 receiver. i have two two large side speakers. a large middle. and a subwoofer i cant get to work. (all kenwood) i also have 2 bose surround...
Manuals help. Read them. Nothing in your receiver is actually a multichannel source so you'll be needing to understand the external sources that originate that kind of programming. Manuals.
Here's one...
http://www.retrevo.com/support/Kenwood-VR-309-Receivers-manual/id/480dj195/t/2/
Try the other manufacturers' support sites for your unidentified gear, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
'Large' is not literal in the context of Bass Management. It refers to the ability of a given speaker to handle REAL bass. Yes = Large, No = Small. 'Small' redirects bass from that speaker channel to the sub.
Web search concepts like bass management, speaker placement, multichannel sound, digital audio, etc.
Sep 05, 2011 | Kenwood VR-309
Cannot get the subwoofer to play...all other speakers work fine...my Kenwood receiver is VR-309...the subwoofer model is Kenwood SW32-HT... I have also used the setup mode to make sure the Subwoofer is...
After making sure that your subwoofer is receiving power, as most models have their own amplifier, make sure that it actually is turning on. There is a possibility of a faulty power switch. Lets rule that out first.
Once the switch is on and the proper power connection is verified, turn your attention to the setup menu on your receiver. Navigate to the LFE/Sub output level. Adjust it up all the way. Then navigate to the crossover setting. Turn it up all the way. If the subwoofer also has it's own control panel including a crossover, turn that up all the way as well. Then with an input on the receiver that has a subwoofer output set up such as for DVD, play some audio. Or likewise you can also use the receivers' test tone capability that will pan each channel individually with a wide band pink noise signal that also includes a signal sent to the subwoofer output.
If this procedure does not produce results then send me a message including your subwoofer model and your observations of your systems' operation.
Jun 10, 2011 | Kenwood VR-309
How do I connect my Kenwood VR-715 surround sound system, Dish Network receiver, and HD LCD TV together so the surround sound works? Can't figure out what goes in the input, the order of the connections or...
The best way to do this is to connect you dish network receiver is directly to the tv. Try to use the best video type possible. HDMI is the best, next is component and lastly is composite. This will take care of the video portion. Next, connect digital audio output to the Kenwood Receiver. I dont know what type of a digital audio output your dish box has, but your kenwood receiver has both optical and coaxial inputs so you should be fine there. Once you have both audio and video wired, change the inputs on both your tv and kenwood receiver to the inputs you are connected to. You might need to set up the kenwood to tell it that your running digital audio to it in the setup menus. Hopefully this helps, let me know if you need any clarification.
Good Luck
Jan 08, 2011 | Kenwood VR-715 Receiver
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
I have a vr 309 kenwood reciever with a bad subwoofer port because sub doesnt produce sound through it but does through another reciever, is there a fuse or capacitor just for this output i can check or...
Are you sure the VR309 is sending a signal out through the sub port? Attach one of your other speakers to it as a test (low volume). Then get back to us.
There are such things as user settings that affect this.
Dec 05, 2009 | Kenwood VR-309
Kenwood VR-305 receiver surround speakers will not work
make sure that all input cables are in the correct positon also make sure that any inputs you are using don't have a macrovision in them that will also kill your sound due to copyright laws and stuff but main thing check all wires coming in to receiver and if you need more inputs go to walmart and get a rca splitter basicaly its a 1 in two out connection to add more cables in the input
Mar 16, 2009 | Kenwood VR-305
Unit does not detect/play dolby dts/5.1 from DVD
make sure that the the DVD setting on your reciever is set to look for the the fiber connection (if it is not looking at the coorect input it will not work)
Oct 04, 2008 | Kenwood VR-309
Comes on but no sound
do you have a cable box? if not the most you can hope for is stereo.
Jan 18, 2008 | Kenwood VR-309
Kenwood VR-309 Logo
413 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
