Question about Sony BDP-S300 Blu-Ray Disc Player
Drops network settings and will not connect to my network
  • 4 Answers
When this happens to me (different equipment, by the way), I can often fix it by recycling (power off, wait a few seconds, and then power back on) my router. YMMV.
Posted on Mar 31, 2014
How do you set tablet to static IP?
If you have Android 3.x, use this procedure:
1)Open Settings
2)Touch Wireless & networks on the left
3)Touch Wi-Fi settings
4)Find the network you wish to connect to and long press it (touch and hold).
5)Touch Modify Network
6)Touch the IP Settings drop down and change from DHCP to Static
7)Enter the settings for your network - if you are unsure what settings to use, contact your network administrator
If you are using Android 4.0, then use this procedure:
1)Open Settings
2)Under the Wireless & networks heading on the left, Touch Wi-Fi
3)Find the network you wish to connect to and long press it (touch and hold).
4)Touch Modify Network
5)Touch the Show Advanced Settings check box in the lower left corner of the dialogue box. If the Show Advanced Settings option is not displayed, you may need to go back a step and Touch Forget Network, and then, when you reset up the network, you will see the Show Advanced Settings option
To ensure that you have got Static IP visit IP-Details.com to have an IP lookup.
May 18, 2014 | Samsung Galaxy Tab Tablet PC
Limited acess with wifi bluetooth error with Asus K55VD-SX405
If windows7 open network and sharing center then manage wireless networks then remove all networks there then click on change adapter settings right click your wireless LAN \proprieties\TCP/IP V4 use automatic IP and dns \ok\ok then disable enable it then try to connect.......Good Luck
Feb 03, 2013 | Computers & Internet
I dont how to connect my psp slim to a wireless network connection
Check that out or follow the below.
  • Turn on your PSP by moving the power button on the right-hand side of the console in an upward motion. Under the console's main screen, go to the "Settings" icon. This is the first icon listed and is farthest to the left. From the drop-down menu, choose the "Network Settings" option at the end of the list.
  • 2
    Select "Infrastructure Mode" and press the "X" button. Select the "New Connection" option to add a wireless connection to your PSP. Choose the "Scan" option to instruct your PSP to search for accessible wireless connections in your area.
  • 3
    Select a wireless connection from the connections your PSP is able to access. Confirm the name of the network and press the right arrow button. Confirm the security encryption settings for the connection. In most cases, the PSP will determine the network's encryption automatically. Enter the wireless connection's password if the network is secured.
  • 4
    Name your new wireless connection so that you will be able to identify it in the future and save your settings. Run a test connection to ensure you are able to connect to the Internet through the wireless network.
  • 5
    Press your PSP's "Home" button at the bottom left-hand side of the console. Move your cursor to the right to find the "Network" icon. Select the "Internet Browser" option from the drop-down menu. Press the up directional arrow and press "X" to enter a web address into the browser. Once you enter a web address, your PSP will automatically connect to the Internet using the WiFi connection you set up previously.
  • if you are satisfied with this response please thumbs up or write a testimonial good luck!
    Jun 01, 2011 | Sony PlayStation Portable Slim Black...
    I tried to connect to internet from my psp2, but always connection erroe occured. Please advise how to set up wifi connection. Thanks
    Hello
    To connect your PSP to the Internet, you must manually configure the WiFi settings for your device. The PSP will not automatically search for and connect to available wireless
    Nov 14, 2010 | Sony PlayStation Portable (PSP) Slim...
    My internet keeps dro, i have installed filters ,
    There is one case where everything is fine but still connection drops too often.---
    This happens when the network type of your laptop is "public" as ublic networks are less secure, routers usually drop connections after sme time. Change the network type to "private". This should solve your problem. There is one more setting in your router where is says something like "automatically login when disconnected". Selecting this option allows automatically login to ISP when connection is dropped from ISP temporarily.
    If network connectivity itself is the problem then you can debug followingly.
    Step-1:
    If ISP company says everything is fine from their side, then you need to check your router. To confirm this first connect the wall outlet of ISP to your laptop and check network connectivity. If there is problem, then ISP has to fix it.
    Step-2:
    If connection works fine then ISP is fine and you need to check your router settings. Now check network connectivity by connecting the laptop to the router through a ethernet wire. If the network does not work then your router hardware could be wrong and may need servicing or replacement. If this works fine then go to step-3.
    Step-3:
    Try resetting your router by using a paperclip. Usually the reset button can be found at the backside of your router. This will reset all the settings and there by making as good as a fresh one. Try to access internet from a place close to router where router signal is strong.
    Change authentication and other network settings of your router to connect to ISP. Now network should work fine. Ensure that you set router password to avoid unauthorized access to your router by others.
    Nov 08, 2009 | D-Link Computers & Internet
    I'm having a problem with my NETGEAR WGT624v3 router. I have it connected through a SPEEDSTREAM 4200 modem and have experienced no problem with the internet connection. However, after approx. 3 to 4 hours...
    yes set the speedstream modem to log in. it is uner advanced, usually 192.168.0.1 address. It is most likely set to "bridged" mode and using the router to login. set login to ppoe on speedstream on one p.c. only 1st. with login ang password filled in and "smart keep alive" on.
    Oct 31, 2009 | NetGear WGT624 Wireless Router
    My wireless network gets dropped
    HI! that is correct.. your device wont connect bcoz you change the wep, ssid name etc on the router.. if the security settings is change from the router and your wireless devices have the old settings it wont work and it will not connect.. you need to enter the new wep, ssid name etc to the wireless devices in order to connect to the wireless network..
    Jul 10, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
    MC50 Internet Access Issue
    Go to Start > Settings> Connections tab.
    click on connections icon and select advanced tab.
    Click on select networks.
    Ensure that both drop down menus are set to my isp rather than my isp and my work network.
    This should get you up on the web.
    Feb 07, 2009 | Symbol MC50 Portable Terminal
    Wireless phone connects and then drops.
    I switched to a qwest modem and a lynksys router. Works flawlessly now.
    Feb 04, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
    BT Voyager 2091 Wireless ADSL Router - DROP OUT
    If you face frequent drop outs confirm with your isp that it's not a problem with line...and also check the physical setup of broadband check if your router is connected to main socket of your house where telephone line enters in your house......
    now when you face drop outs check on your hard wired comp whether you remain connected or not if no its a problem with line..
    if no reconfig your bt router for wireless network change the channel of your wireless network either to 1 or 11...
    or either there is one other way reset your router to default settings by pressing the pin at the back of your router..
    and after that your router will start its default wireless network i.e a unsecure network..
    try connecting to that network if still the same there are drop outs it's a problem with router....contact bt to config the router...
    Oct 01, 2007 | Computers & Internet
    Sony BDP-S300 Blu-Ray Disc Player Logo
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
