Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Oven made groaning sound for a second or two then blew the internal fuse. After replacing the fuse the lights, fan, clock worked fine. The clock was reset. Pressed the start button again and heard the groaning sound for a second or two and the internal fuse blew again.
    Sergeant:
    Champion:
  • 282 Answers
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Posted on Apr 10, 2014
MicrowaveSvc
  • 9098 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
techcrazy
  • 72 Answers
SOURCE: Microwave does not work
please dont forget to rate me on this issue...
Posted on Feb 02, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker Microwave-Model # JVM1441WD003 no heat -clock ok
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Feb 15, 2009
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
GE spacemaker XL microwave oven blowing fuse
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the house fuse or breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | GE Profile Spacemaker XL 1800 36 in....
My ge profile spacemaker II microwave went dark, no lights of any kind and no sound or response when pressing any button. tried resetting the circuit breaker but no change
Did you check the internal fuse? Often when everything is dark the fuse that protects the microwave is blown. Take the old fuse to your local hardware store and they will have a replacement for you. Should cost less than $5.
Nov 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1430 Spacemaker is dead. Completely.
See my microwave oven safety file here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. How to test a high-voltage capacitor.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. My door switch help file.
If the fuse is easy to twist with your fingertips while it's in the holder, it's too loose.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 29, 2017 | GE JVM1430 Microwave Oven
Microwave runs for split second then shuts down blowing fuses in the kitchen. GE Spacemaker XL 1800.
Hi .. your problem is most likeliy inside the microwave itself. I would replace it. Or you can take it to a shop that does repairs to get a diagnoses and estimate .. but replacement might be the less costly.
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
My GE jvm230 blows fuse when the start key is pressed. Refused and all is well until start key is pressed again and the fuse blows. I think my HV cap. is shorted. The HV capaciator isreading less than 1...
It might be the cap but it is probably a bad diode. The diode if shorted to the cabinet will of course blow the fugging fuse every time. The diode should have continuity in one direction only. If the 2 leads between the mag are shorted to chassis the fuse will also blow. You have 3 suspects the diode the cap and the mag. I would replace the cheapest thing first and that would be the diode and i am correct a shitload of times. Peace brother.
Jun 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Space Maver MIcrowave
If it blows the fuse as soon as you hit START, you probably have a high voltage capacitor shorting. If it blows a fews secondfs after you press START it probably has a bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 You might also double-check the magnetron. The technical sheet inside the oven shows you how to check it.
May 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
171 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
