Question about Chrysler Dodge ram van,ram wagon radio, e.t.r w/clock, radio, e.t.r. w/clock
No crank, no start on 1991 Dodge Ram Van B2500 5.2L. Starter good, testing postive for power at imput and power connections on starter. When key in start position , solenoid clicking and ASD relay (mo
Can't find the starter relay to check it, and fusible links are all sound. May be the ignition switch? Am I missing something? It died yesterday out of the blue, no crank, wouldn't start on a jump or a knock on the solenoid. Evenually got it going by shorting the power and imput wires on my starter to give it a boost. Tested a bunch of electrical connections today -- got power at the starter so replaced it and still not turning over. Help!
    New Friend:
First jump the starter to see if starter works
Posted on Sep 25, 2014
1999 dodge ram van 3500 starter engages while engine is running only in park or neutral. Had to pull starter relay to disengage starter, also starter relay somehow connected to blower motor high speed
Check ignition key switch wiring. Could be a short between blower motor wiring and starter wiring. Try switching on high speed blower when ignition is on only (not started). If the starter cranks, then there is surely a leakage/short in the wiring.
Dec 28, 2016 | Dodge Ram 3500 Cars & Trucks
1994 Dodge Ram Van B250 Check Engine light doesn't come on, van won't crank, won't start....nothing when key is turned on It is not battery......buzzer and such does come on when key is turned on
I know you said it isn't the battery, forgive me, be sure the battery has a full charge and battery connections all good. Use a test lite and follow battery voltage. Battery ground is important also.
The battery voltage may lead to junction block--fusible links--fuse box?
At the fuse-box, pick any component that has a fuse, check fuse circuit for voltage, use a test lite. Some fuses are hot all the time, some go hot with key on, test both ways.
If the starter motor won't crank, check voltage and ground for the starter motor. Usually two voltage circuits at the starter motor, one comes from the battery, hot all the time. The other circuit goes hot with key in the crank position and is probably wired through the clutch or neutral switch then through the starter relay, where applicable, to the starter motor. The starter motor usually grounds through the engine block, so, battery negative connection is important.
Any testing at starter motor, make sure tranny is in park or neutral and functional parking brake is set. Safety is your responsibility. You don't want the vehicle to move during testing.
Apr 03, 2016 | Dodge Cars & Trucks
2000 dodge ram 3500 starter problem
check the under hood fuse block/relay box,ive seen these go bad, i see you said starter was checked how was it check .also check to see if getting power to starter when you turn to crank,will have to have friend help you,if the test light lights up,give that starter a big smack with bfh! is there a sercurity light coming on and staying on,if so check your key,it could be worn out.there is a starter relay that controls starting is this a stck or auto,good luck,mike
Jan 17, 2015 | 2000 Dodge Ram 3500
1991 dodge ram van b2500 5.2L v8 no crank, no start condition -- out of the blue since yesterday. wouldn't start on a jump or solenoid knock. ended up shorting power and imput wires together on starter...
Go to your computer search for fusebox diagrams and find out where the starter relay is, most likely its a square black box inside the under hood black square fuse block.
Feb 14, 2014 | Dodge Ram 2500 Cars & Trucks
1998 chevy asto van wont crank or turn over
Turn the headlights on and watch them while the key is turned to start. If the lights go out, one of your cables or connections at battery or starter is not good. If lights dim a lot but stay on, possibly a bad starter, it needs testing. If lights aren't affected by cranking position, turn lights off, pull the small wire off the starter solenoid, hook up a test light to ground and to the solenoid wire. Light should come on when key is held in crank. If it does, likely a bad starter solenoid. If no light, then the start circuit from ignition switch to starter solenoid is not working. Check for power out of ignition switch on the start wire with key in crank, to begin with. If powered, switch is good, need to check if neutral safety switch is good, and then check or swap in a new starter relay.
Post back with any results.
Good luck.
Jan 17, 2013 | Nissan Altima Cars & Trucks
1991 dodge ram van wont start
To clarify - the engine cranks then starts.
If it won't crank in any gear, I would check the neutral safety switch first.
You can also jumper the starter solenoid to make sure the starter will crank the engine manually without the circuit from the key switch.
Jul 24, 2012 | 1991 Dodge Ram 350
Van wont start. no power
Maybe the starter or starter solenoid is bad. First, make sure connections at battery and starter are clean and tight. Old school method: turn headlights on, and (if good and bright) observe them while someone turns key to crank. If they dim noticeably and starter makes no sound, likely the starter has failed. If you observe no difference in headlight strength, then likely the starting circuit from ignition switch to starter solenoid is not working. You could take the wire off starter solenoid and see if it has power there while key is in crank position. If you do have power there, starter needs to be tested, or the solenoid is bad. If no power to the solenoid when cranking, then the circuit from the ignition switch to the solenoid will need diagnosing. Your neutral safety switch, and possibly a starter relay is in that circuit before it reaches the solenoid.
Good luck.
Feb 01, 2012 | 2002 Dodge Caravan
My dodge ram van wont start no spark replace many parts
i know alot of crysler/dodges had a crank sensor i had 1 go out on mine check see if you got 1 chances are thats it when mine went out it would turn over but no spark
Nov 30, 2009 | 1994 Dodge Ram
I have a 1992 Dodge Ram Van 318 ci. It died while driving. No ignition, no check engine light, starter won't crank. Battery is good, cleaned posts, changed ignition switch. Still nothing, any ideas?
There is a starter solenoid between the battery and the starter. Check that to see if it has gone bad. It will not set a light. you can jumper from the power lead to the starter post to see if it engages. Be sure you are in neutral if this is a standard shift because you will be bypassing the neutral switch. The solenoid is on the firewall or well well depending on your options configuration.
Hope this helps
Oct 15, 2009 | 1992 Dodge Ram 250
1988 Doge Ram will not turn over.
check your starter relay in the power distribution center. if you are not getting any crank. with a test light or dvom you can check the small signal wire on your starter solenoid when the key is in the crank position there should be power on this wire. it sounds like you are not getting signal to the starter from the ignition switch
Apr 16, 2009 | 1988 Dodge Ram 50
Chrysler Dodge ram van,ram wagon radio, e.t.r w/clock, radio, e.t.r. w/clock Logo
112 people viewed this question
Top Chrysler Car Audio & Video Experts
Tom Chichester
xxxxxx xxx
 Mikey
Mikey
Are you a Chrysler Car Audio and Video Expert? Answer questions, earn points and help others
