Question about Sharp CD-SW340 Shelf System
Timer light flashing on a sharp cd-sw340 unable to turn on
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I have sharp mini component
Turn the Timer OFF.
http://dl.owneriq.net/a/ac88b963-e6d2-4447-be4d-8e43c83cac5a.pdf
Posted on Apr 29, 2011
thump3r2389
SOURCE: my sharp cd-sw330 has somehow
what if u dont have the remote any more
Posted on Aug 18, 2013
I have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing
replace swollen filters on power supply,if still not working output ic needs replacing also.
Nov 13, 2013 | Sharp CD-SW330 Shelf System
Cd tray is not open
The problem could be a broken loading belt, the gears are jammed, or the timing of the loading system is out of sync.
Mar 19, 2012 | Sharp CD-SW340 Shelf System
My sharp cd-sw330 has somehow entered the timer mode. The timer light just flashes periodically and the pwer wont come on. I dont have the remote. How else can i disable the timer.
Get the manual out and look at page 40.
"Cancelling the timer setting in the timer stand-by mode"
1 Press the CLOCK/TIMER button.
2 Within 10 seconds, press the '<< << or >> >>' button to select
"ONCE" or "DAILY", and press the MEMORY button.
3 Within 10 seconds, press the '<< << or >> >>' button to select
"ONCE OFF" or "DAILY OFF", and press the MEMORY button.
Timer will be cancelled (the setting will not be cancelled).
http://remotes.com/remotes/servlet/rs?&smodel=SUG90&brand_pn=TECHNICS_SUG90&o=c&o=c&a=Search&uid=0&m=CD-SW330&uuid=A13127573893951
or
http://www.dvdremotecontrols.com/Mfrs/Sharp/SharpAudio/RRMCGA117AWSA.htm
model: rrmcga117wsa
Aug 07, 2011 | Sharp CD-SW330 Shelf System
I have sharp mini component system cd-sw300h and can not switch the machine on . The timer light is flashing but I cannot seem to get the unit to turn on at all.
My sharp mini component CD es777 won't work. it only flashes a red light where timer is. I tried the remote timer but still no luck. Help
Apr 29, 2011 | Sharp Shelf System Shelf System
TIMER LIGHT BLINKING AND POWER IS NOT COMING ON CD-SW330
i have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing, i have done the bit it says about pressing the timer button then arrows and memory but that doesn't seem to work help?
Jan 09, 2011 | Sharp CD-SW330 Shelf System
I have rear projection tv sharp 55u-wp7h. Unable to turn on tv due to view timer automatic turn on. what cause that and how to fix the problem?
I'm having same issue with same TV. It powers off after about an hour and red power light starts flashing. Only way to power back on is by unplugging TV and waiting a while, then plugging it back in, but then the TV will turn off again after a few more minutes, red light flashing again. I've checked the sleep timer and it is turned off, so any other solutions to this problem? All capacitors on power board look fine (not blown). I've read it could be solder joints in power board need to be resoldered.
Dec 17, 2010 | Sharp 55R-WP4H 55" Rear Projection...
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
The timer light on my tv keeps flashing and we are unable to turn tv on...help!
The V26 Chassis DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacment capacitors and the CD with detailed repair instructions
Nov 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sharp CD-SW340 Shelf System Logo
49 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
