Question about Electric Mobility Health & Beauty
Motor whine Heartway Ranger PF5 motor whining when under power
    Scholar:
  • 61 Answers
You may have bad bearings in the motor. I would suspect the gearbox. Have you had any issues with the gearbox leaking oil. The bearings/bushings on the drive shaft for the wheels are most likely going bad. If this is the case, you will have to replace the whole axle assy.
Posted on Apr 19, 2014
There is a loud whining coming from the motor
Hi Tyler:
Try using a mechanics stethescope (or a dowel sound rod, thumb over end held against your ear) and with the engine running, touch various components. You will hear different sounds, and hopefully be able to isolate the whine.
CAUTION - Work Safe - moving bits can make the sound rod hurt you.
I'd be guessing at an alternator bearing as they whine worse than a puppy on the wrong side of a door.
Cheers
Jan 07, 2016 | 1995 Mercury Villager
My 96 ford ranger 4.0 liter whines while at a low rpm range an ideals rough while its whining i can get the whining to stop by gooshing the gas petal
Whining is typically one of two things. The power steering fluid is low or the water pump is on its way out.
Feb 25, 2015 | Ford Ranger Cars & Trucks
Motor whine when under power heartway PF5
Hi, well it's the bearings normally, the end connected to the gearbox, this a stress area for the motor, personally i wouldn't worry unless it actually slowing down or grinding , vibration so enjoy...
Regards
Rob
www.gewizrepairs.co.uk
Feb 14, 2014 | Electric Mobility Health & Beauty
My 87 Ford Ranger makes a whining noise when accelerating, all though everything SEEMS to be running fine, what are the higher chances of what could be wrong?
rotate steering wheel back and forth,if whine noise changes, p\s pump is causing whine. common problem with ford.
Jan 22, 2013 | Cars & Trucks
2005 Ford Expedition motor whines
The cause of the whine would likely be the power steering pump, as there is no other part that really can create a whining noise. Have a local shop listen to it before you buy or replace any parts please.
Sep 18, 2012 | 2005 Ford Expedition
1995 Ford Ranger whines. Three mech's, fuel pump, carrier bearings, wheel bearings. Who is closest?
You need to post the symptoms of your problem. And let us tell you what we think. But for what its worth here I go. Electric fuel pumps howl or moan. Carrier bearings on make noise when vehicle is moving down the road and make a squalling noise when the bearing is going bad but may be interpreted as a whine. Wheel bearings near the same as carrier bearings but they usually grind. So my guess is alternator or pulley bearing since they whine.
Mar 04, 2011 | 1995 Ford Ranger Supercab
Power steering pump is whining, I replaced it and the new one whines just as loud. what could be wrong
make sure your using power steering fluid recommended for the vehicle. If automatic transmission fluid it aerates causing bubbles. It's very similar to the effect of shaking a bottle of liquid detergent vigorously when half full. Having that much air in the system can cause it to whine very loudly and reduce the life of the pump.
Oct 14, 2010 | 1999 Ford Ranger SuperCab
Whining sound from under van only when i push the gas.
The serpentine belt is the most common cause for whining sound when accelerating, try to understand if noise is coming from serpentine belt.
Also check power steering belt under steering column, and also the rotor and chain, thei do not make whining noise , but can make noise when accelerating.
The belt is first suspect.
Mar 26, 2009 | 1988 Chevrolet G20
Health & Beauty Logo
114 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
