Question about Maytag MAH2400 High Efficiency Front Load Washer
Washing machine model DC68-02032A, no filling up with water stoped wording
Slow in water until stop working
Illeagle
  • 525 Answers
SOURCE: Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
Posted on May 24, 2008
  • 15 Answers
SOURCE: Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Posted on Jan 17, 2009
tomsat69
  • 214 Answers
SOURCE: Maytag washing Machine
It sound like you have a bad float switch and it is not reading the water level right.If it is filling and wont stop then a possible new water valve is in order:) The float switch is locatted under the top panel of washer
Posted on May 07, 2009
beltronic205
  • 1466 Answers
SOURCE: Why my Maytag model performa, washing machine fill
Check drain hose not too low ...Syphon Effect....Good luck
Posted on Sep 29, 2009
SOURCE: Maytag washing machine stopped working mid wash cycle
http://appliancejunk.com/forums/index.php?topic=2946.0
Go to the above link, get a suitable service manual, and follow the troubleshooting procedures
Washing Machine FAQ
Appliance Repair Guide: How To Fix Appliances - ACME HOW TO.com
DIY help site.
Posted on May 02, 2010
Washing machine stopped working. The lights come on but water wont start filling
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 25, 2011 | Washing Machines
No hot water. everything works in order,but with cold water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Apr 21, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Slow filling Model lw4303wi
heatman101
Apr 15, 2011 | Amana Washing Machines
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
heatman101
Mar 30, 2011 | Washing Machines
Water isnt going into the machine
heatman101
Dec 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My Maytag LAT9400 top loading washer has stopped allowing hot water to enter the tub, only cold water works. What might be wrong?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 06, 2010 | Maytag Washing Machines
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Washer agitates while filling and runs water when it should be spin cycle
filling and agitating at same time could be pressure sw / but if filling in spin / I would replace water valve . sounds like its stuck open . . when washer stopes does the water stop. ?? if not may be timer .. your is hard to diag . need to know brand and model # ,, mm
Dec 08, 2009 | Washing Machines
Kenmore model 8566645 Washer is connected and runs but water flows out of the bottom and not into the tub.
Remove the front and side panels if you haVE TO. Look for a bad water pump most common on older units.
The fill tube to the tub from the fill valve is a second likely problem
I water filter located under the tub and in line with the water pump is also a possibility.
A bad hose is not likely but a connection to a hose could be a problem.
Jul 10, 2009 | Kenmore Washing Machines
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAH2400 High Efficiency Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
