Question about Magnavox ZV427MG9 DVD Recorder VCR
Tape was caught inside i have removed it but, right side of tape deck doesn't seem to move easily like the left whats wrong
3 Suggested Answers
atang1
  • 734 Answers
SOURCE: Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Posted on Feb 21, 2012
SD Tech
  • 14553 Answers
SOURCE: vhs tape stuck in vcr
Some one needs to open it to see if the tape is loaded but wrapped around a post or tangled up.
What usually causes this is the mechanism that moves the tape has a problem---bad or broken belt or rubber drive wheel that moves tape is bad.
Its called eating tapes.
With it apart you may be able to extract the tape and then insert with it apart to see if reels etc are or are not moving in RR and FF first and then in play to see what is not moving.
Posted on May 27, 2012
I have a used Marantz PDM510 dual cassette deck. Both decks seem to be doing what they're supposed to (tape is moving fine) except no sound is showing on the indicators and no sound is coming through...
I have a Marantz PMD511 which is almost identical. I'm not certain exactly what the difference is, but I don't think it would be anything that would make this problem not apply to either.
It's hard to imagine that both decks would go bad at the same time, but, of course, it is possible.
I'm guessing you problem is on playback. Of course, the very first thing to do is make certain that there is something recorded on the tape. Even if you think there is, make sure by playing the tape in another player...any player. One time a friend of mine laid a cassette tape down on a high-powered speaker laying in my studio, and the magnetism wiped the tape clean. So...make sure. A clean tape would be the most likely reason for your problem as you have described it.
Next, I'm thinking you've tried both decks, which remember, are totally independent.
Of course, if neither set of meters are showing a signal from either deck (A or B), it doesn't look good. Again, re-check the tape itself.
Good luck, Tom
Aug 07, 2011 | Audio Players & Recorders
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
SONY TC-WR550z dual tape deck eats tape and doors won't open I hadn't used this unit in 5 year (it's 13 or 14 years old), and before it worked fine. I went to use it again last month (MJ "Thriller" tape!)...
I don't know anything about the "eats tapes". You can take out your tape fairly easily thought. All you need to do is
unscrew screws on the left and right side of unit
remove the cover
use a flat head screw driver to gently push down on a white lever on the side of the drive mechanism while pushing the eject button
Sep 13, 2009 | Sony TC-WR565RM Single Cassette Deck
BOTH doors jammed on TC-WE605S
Some tape decks are belt-drive. If the belt is worn, it will either break or jump the cog and you will experience these kinds of problems. That's what happened with my Sony ES deck recently and I couldn't even eject the tape until I got the belt replaced.
Jul 30, 2009 | Sony Audio Players & Recorders
Vhs tape won't load completely
I assume the cassette flap lifts fully, allowing the tape to go into the deck as this is a small lever mechanism. When the tape goes so far in, it activates a switch to start the loading motor this is usually a metal or plastic pin on the deck depending on the make of VCR (as you do not mention the model of your VCR, I can only give you an overall explination of a carriage mechanism). The pins at the side can incorporate a start sequence as well & will guide the deck into position. It looks like your machine has gone out of alignment & to solve the problem you would need to remove the cassette housing & re-align the pin at the side so that it follows the correct path, this can sometimes be a tricky & awkward thing to do as you can break parts of the deck if it is not aligned correctly. My advice would be to take it to a service repair centre.
Jul 21, 2009 | Televison & Video
I have a Stereo Double Cassette Deck; Pioneer CT-W404R. I've set the REV MODE switch; I've pressed the record button; I press playback and the tape for recording begins moving, but not the other tape. If I...
I was following instructions for "Recording." On the next page were instructions for "Tape Copying," though the first page began with, "Load a tape for recording in Deck II." That sounded like what I wanted. Anyway, that was my error.
Oct 11, 2008 | Pioneer Audio Players & Recorders
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
IBM Selectric used ribbon won't wind into spool
The ribbon sometime gets wrapped around the ribbon driver,One lever on the right side only releases the lift off tape for removal the other is for ribbon removal, also check that the ribbon is on the outside of the ribbon tensioner where the ribbon exits the cartridge on the left side ( a wire thing with a plastic tube on it.
Jan 29, 2008 | Lexmark Wheelwriter 15 Series II...
Dual tape deck inoperable
clean the rubber pinch rollers with an alcohol swab. the tape is not getting required "grab" on these rollers and not pulling tape. the auto reverse is an attempt to rewind the tape because of confusion with no tape movement.
Nov 12, 2007 | Yamaha KX-W321 Single Cassette Deck
Magnavox ZV427MG9 DVD Recorder  VCR Logo
29 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
