Question about Briggs & Stratton Garden
Black spark plug - Briggs & Stratton Garden
    Novelist:
  • 157 Answers
Indication of running rich, bad or incorrect fuel or loss of engine compression or extended idle.
Posted on Jul 22, 2016
CHANGING SPARK PLUGS ON A 2002 LINCOLN LS
Generally in a spark plug is 60000 kilometers, if fuel is bad need in early, remove the spark plug, such as for auburn or rust color, spark plug showed normal; Such as stained with oil, shows that the spark plug gap imbalance or too much oil, high tension line short circuit or open circuit; Such as black smoke, spark plug type cold wrong or mixture is thick, the oil is up; Such as the top between the electrode and sediment, when for the oily sediment, shows that the cylinder into the oil has nothing to do with the spark plug, when the black sediment, spark plug carbon deposition and bypass, when grey sediments, is a gasoline additive covered electrode lead to lack of fire; If serious erosion, such as the scar at the top, with black pattern, electrode melt, showed that the spark plug is damaged.
hope help you -auto diagnostic tool
Apr 02, 2013 | 2002 Lincoln LS
Spark plugs are black on my Harley
Hi Anonymous, and the usual suspects are:
1. Plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discarged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. If your bike has a CKP sensor you must leave both plugs in
head and check for spark with a 3rd plug. Good luck and have nice day.
Apr 01, 2013 | 2003 Harley Davidson FXSTDI Softail Deuce
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Jun 16, 2012 | Toro Power Lawn Mower
Have a skilsaw 1616 chainsaw that will not crank. Cannot tell if it is firing or not. do not know how to test the lead to the spark plug from the black box (don't know what it is called) the wire is...
Remove the spark plug wire, remove the spark plug, reattach the spark plug wire to the spark plug, ground the threads or the flats the socket engages to to the engine. While grounded, pull the recoil starter and you should hear a popping and see a spark. May not see the spark if done in bright light, like direct sunlight.
Aug 12, 2011 | Garden
Heater not starting , think the spark plug connector is not working. Is it possible to run straight to the spark plug and bypass the black box. 55000 btu keryosen heater.
the black box the wire that comes from it and goes to the spark plug is the ignition module,no you cant bypass this or there wont be any spark,make sure though that when unit is powered up theres 120 volts at the input of the black box,(where the power goes into) the box,not on the spark plug wire side either
Mar 13, 2010 | Reddy Heater-30-55,000 BTU Variable
No spark at the spark plug. Kohler 16 hp
1) How have you determined that there is no spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Dec 04, 2009 | Craftsman Garden
My stihl chainsaw has no spark. spark plug is new
thanks, rwvanlue
Nov 16, 2009 | Garden
Do not know where to connect hour meter wire to the spark plug
One wire is the flexible silicone rubber wire from the spark plug to the ignition coil. You don't have to strip or connect the other wire, just wrap it around the spark plug wire a few turns.The current from the spark ignition will induce a signal into the hour meter that the meter uses to determine when the motor is on or off. I hope this helps and good luck.1b05a64.jpg
Oct 28, 2009 | 2006 kawasaki KX 250 F
Spark Plug location
Yes sir! Those four square black modules are the distributor caps for the spark plugs - ie they distribute the high voltages to the plugs to ignite your gas that makes your car go :)
Be careful when you're unscrewing the plugs - there is likely grease, oil, or dirt around them and knocking any of this through the spark plug hole down into the cylinder is potentially damaging to the engine. Best of luck!
Sep 18, 2008 | 2004 Toyota Camry
Garden Logo
29 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
