Question about Shark Navigator Bagless Upright Vacuum
Shark vacuum thermal overload
Motor doesn't run, overheated
2 Suggested Answers
  • 2119 Answers
SOURCE: WHERE CAN I GET A MOTOR FOR A SHARK ROTATOR VACUUM ?
Shark Clean
I doubt that they will sell just the motor if they do don't be surprised if the replacement motor costs more than the vacuum.
Posted on Oct 04, 2014
Will not maintained power in high setting. Runs fine in low power setting.
I would recommend thoroughly cleaning all filters, most likely the high setting is overheating the motor and the thermal protection circuit is tripping. In other words, the motor isn't "breathing" well.
Mar 15, 2016 | Electrolux 2-in-1 Stick Handheld Vacuum,...
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power is not coming on
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
It runs for a couple of minutes shuts off then restarts 30 seconds later runs a couple of minutes and does this over and over
Most vacuum motors are protected from overheating by a thermal switch that resets after cooling down. Check for blockage in the hose,
power head or a full bag that would block cooling air from cooling the motor.
Tom
Oct 22, 2009 | Tristar Vacuums
Motor cut out - overheated
Should reset after an hour or so, clean filters and make sure dry first
Nov 23, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction
Sounds like your motor bearings are going bad. This is generally indicated by the motor overheating, and the heat transferring out through the motor pulley, which is where the belt attaches. So, your machine is overheating, melting the belt, and then tripping the thermal cutout. When it cools and you restart it, the belt is no longer functioning due to being melted, and this would make it not pick up on carpet. If you look at the motor pulley and it is turning blue: this is indicative of overheating.
The other possibility is that there is a clog, which is also causing your motor to overheat; so before you throw it away make sure all of your air pathways are clear.
The fact that you've had it 8 years is somewhat remarkable, however, since most vacuums of this type are averaging a 3-5 year lifespan. (And half that for bagless.)
So, check for clogs, and if it's not clogged, you're probably due for a new machine.
-R
Oct 01, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Where is the reset button on the electolux 2100
There is no reset button on the 2100. If it shuts down, the indicator lights will tell you why. If it has been overheated, there is a self-resetting switch which will shut the motor down and the light will come on to indicate that particular problem. When you turn the machine off and then back on, it should re-start provided you have given the motor ample time to cool down. This will not solve the problem as to why it overheated in the first place. There are also lights and auto-switches that will control full bag and no bag. The machine will not run with no bag and a full bag will cause it to run for a few seconds and shut off.
Mar 20, 2008 | Vacuums
Filterqueen cuts out when warm
You should check the disc filter that is located under the paper cone support. The support is secured with a single screw in the middle at the bottom. This filter is commonly overlooked and when it gets dirty will restrict airflow and cause the motor to overheat. Most motors have a Hi-Limit switch incorporated into the motor to protect against overheating. You should also check the top filter (which is probably foam) and replace if it is clogged.
Jan 11, 2008 | Filter Queen Majestic Canister Vacuum
Shark Navigator Bagless Upright Vacuum Logo
205 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
