Question about Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone
Freezer working fine, but fridge not cold - Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone
5 Suggested Answers
SOURCE: samsung fridge freezer
I had the same problem. Just about 10days ago and of course warranty was done in January 2009. Luckly it was inexpensive to fix (less than $ 100). It was just frustrating to be without our fidge that long at this time of year. As well it was quite a challange to get the right part as Samsung is kinda the new kid on the block. Not sure if was the repair man on this end or the supplier but we eventually got the one we needed. you need to replace the fan motor on the fidge side of your unit. That solved our problem. Hope this helps cuz i feel your pain
Posted on Aug 03, 2009
zaldyboy01
  • 293 Answers
SOURCE: My fridge is working but not cold enough. Freezer
DEFROSE YOUR FRIDGE IN ONE DAY OR TWO DAYS UNTIL THE ICES ARE MELTED AND CLEAN
Posted on Feb 15, 2010
heatman101
  • 43501 Answers
SOURCE: my fridge is leaking water
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 28, 2010
  • 1456 Answers
SOURCE: The fridge temperature display won't
Hello
Run a couple of system self test on the refrigerator to see where the problem has occured
Inspect your condenser fan and get a multitester to test the thermistors if they are still in perfect order,if they do not give accurate readings you should replace the condenser fan and thermistors.
Also check out the fresh food evaporator fan if it has not been iced up as this can restrict air flow and make your refrigerator not to cool
The evaporator fan is behind all the plastic back wall and insulation.replace the fan and the thermistor near the top light and clean out all the ice.
Your refrigerator should now work normally.
Posted on Dec 26, 2010
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
Freezer is working fine. Bottom Control for Crispers working fine. Upper section of fridge not getting cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
May 26, 2011 | Frigidaire Refrigerators
Freezer works, fridge part does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 21, 2009 | Refrigerators
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridge is not getting cold
mine is the same. Top freezer works fine. Frig won't get cold but runs.
Apr 12, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone Logo
29 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
