Question about Zebra S4M Thermal Label Printer
Why is it that when I turn on the power on zebra s4m it automatically feeds on 5 media/labels, is this normal?
3 Suggested Answers
  • 32 Answers
SOURCE: Zebra S4M label printer
Check the drive belt. It might be missing a tooth if the printer is older. I can assist if you want to check this.
Posted on Oct 27, 2009
  • 185 Answers
SOURCE: S4M automatically feeds extra labels everytime it's turned on
Set your print driver to "Do Nothing" on Head Close and Power Up. the next time you print will pass this information to the printer and the problem will not come back - actually the default for the driver is "Do Nothing" so it has probably been changed for some reason, you will need to change it back.
Posted on Oct 29, 2009
Restore defaults
hold pause+feed buttons while turning on the printer. release after 10secs.
Oct 01, 2013 | Zebra S4M Thermal Label Printer
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
Print 4 blank label when zebra s4m print switch it on, everytime. why please give assistance!!! thanks for advice
Look around in the control panel set-up parameters. You're looking for the setting 'Media Power Up'. By default it is set to 'Feed". Change this setting to 'No Motion". You'll find this in your owner's manual on page 50.
Jul 20, 2011 | Zebra S4M Thermal Label Printer
How do i change the media power calibration on a Zebra S4M printer
Go to www.zebra.com and download the S4M pdf user manual. It guides you how to change configuration.
Oct 27, 2010 | Zebra S4M Thermal Label Printer
HELLO: PRINTS ONE LABEL
This could have a couple of different causes. Best thing to do is determine if the problem is with the printer or the software. Turn the printer off and back on again. After the power-on self test is done, just press the feed key. Does the printer feed just one label ? If so, then you know the printer has a good calibration on the size of the label. Now print a label. Does it skip one after printing ? If it does, now you know the problem is in the software because the printer is only going to do what it’s told to do. Check all settings in the label software / printer driver to make sure label size is accurate, correct printer driver is being used, etc.
So first check to see if the printer is ok by itself. If it feeds two labels after powering up, then the calibration is needs to be redone. Also make sure the media sensor is positioned over the label. This can cause skipping as well if out of position.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
My Zebra LP 2844 printer is not aligned and the info on the tag prints onto the next tag, how do I fix this?
Calibrate the media that is in the printer. Power the printer on while holding the feed key. When it flashed red, let go. It will calibrate, print a config label, then go into dump. Press the feed key again to exit dump. Once this is complete, your printer should advance only one label at a time when you press the feed key. If this is working as expected, but the labels are not printing right when you print from you application, there is a problem with your format or driver settings.
Jan 07, 2010 | Zebra S4M Thermal Label Printer
Settings seem correct, but labels will print on 2 labels, or skip labels. Zebra s4m
The printer is not calibrated to the media length. You need to perfrom a calibration with the labels loaded. This is in the users manual on how to do it. The printer should be set to automatically do this when powered up.
Oct 20, 2009 | Zebra S4M Thermal Label Printer
Apr 12, 2009 | Zebra Z4M Printer
How to feed labels on zebra s4m
The issue that is causing the problem is when users tear off the label they are actually partially pulling on the next label causing it to peel away a little then when it feeds it will jam. Only reliable way to stop this is once the user prints tell them to press feed and feed 1 label through.
Mar 31, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
18 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
