Question about Thrustmaster Ferrari Gt F430 Wireless Cockpit For Ps3
How do i calibrate f430 cockpit on ps3
I cant find any calibration options in ps3 or not even in Dirt3 game...wheel is working without calibration but i have monstrous dead zone in steering everything esle is fine. pls help ...
Missing USB Wireless Dongle for f430 Cockpit - where do I slot in the USB dongle and where do I purchase it? The wireless dongle has gone missing. Thanks
Hi!
I have the same problem. I got this answer:
Regarding your F430 Cockpit Wireless.
We begin by thanking you for your interest in Thrustmaster products.
We would like to inform you that a new Wireless Receiver costs 26 Euros (shipping fees included).
Payment option: PayPal
If you would like to proceed, send us a reply to this email with your complete name, full address details including the postal code and a phone number where you can be reached, so we can create a spare part order and send you the payment details.
Thank you for your cooperation and understanding.
Thrustmaster Technical Support is at your disposal for any other information you may need. You can reach us online at the following addresses:
http://ts.thrustmaster.com/eng for the latest updates and FAQs
or by telephone at one of the numbers listed on the following page:http://ts.Thrustmaster.com/eng/index.php?pg=contact
Jul 31, 2013 | Thrustmaster ferrari f430 cockpit wireless...
Off centered steering on the logitech g25 on ps3
Go on device settings in settings on your ps3 and it should pick up the device. There should be a calibrate icon where once you click on it your screen will turn black and it should beep once it is calibrated. If you have a game such as need for speed it should at start up ask you for device info and will ask you to calibrate
Jun 25, 2011 | Logitech G25 Wheel And Pedals Set
The steering wheel when turning to the left is loose and lost its spring back action. It remains fine on the right hand side. How can we fix it?
There is really only one of two things that will be causing this.
1. Go into the control panel software that came with your wheel and re-calibrate your wheel and verify the force feedback settings in there as well. Also, go into the software you are using the wheel for and check in the settings for wheel/force feedback settings and try redoing those.
2. Your wheel's hardware itself is damaged and only thing you can do in that case is send in for repair (if under warranty) or buy a new wheel.
Feb 17, 2011 | Guillemot Thrustmaster 4160545 Ferrari...
I do not know how to configure the wheel for other games
Hi, If the wheel is connected to a computer with the profiler installed then you can set up the wheel as you wish, but as soon as you plug in the wheel it will run a calibrating process itself.
If you intend to use the wheel on a Playstation system, the wheel calibrate itself when plugged but the settings are " In game " . On Consoles, all the settings are games related/support
thanks and have a nice day J -
Apr 25, 2010 | Logitech Driving Force GT Wheel And Pedals...
Ok well i bought the wheel and i have this game called dirtfactor and i was trying to drive a latemodel and it doesnt turn at all it turns a little but barly......also when i do sprint cars it turns but...
I wouldn't say it's a lack of the wheel being cheap I'd be more inclined to say it's "because" the wheel is cheap. Seriously, Have you tried to calibrate the wheel using the windows calibration routine found in your control panel under Game Controllers.
Obviously the wheel is operating but barly sorry, barely. That means it is working and giving input to your computer so if that input isn't enough you either need to calibrate in windows or maybe there's even a calibration routine in the game you're playing, maybe under options. Calibration by the way is found under properties on the Game Controller section. Try it.
The test section of the windows section will tell you just how far your wheel is turning or directing your cars by means of a box with a cross in it. The more you turn the wheel the further that cross will move. Test it first, then do the calibration and then test it again. I'm sure you'll see a big difference.
Apr 21, 2010 | Genius Twin Wheel F1
When I plug in the wheel to my PS3 and put the adapter into the wall the wheel calibrates and works but when I plug the wheel into my PS2 nothing happens! I've even left it plugged into my PS2 for an hour...
frkzila2, did you ever find a solution to this? I bought this for my son a few years ago and he NEVER used it... now he's in his teens and tried using it but it doesn't work... left light blinks, right light is solid, wheel moved slightly when initially plugged in, but no power what-so-ever to the pedals??? did you ever fix yours?
Oct 04, 2009 | Logitech Driving Force Pro Steering Wheel...
Ps3 laser
hi the problem with this is replacing the laser is the easy part and more or less anybody can do it but to get the new laser to work you need to calibrate it this is what the osciloscope is for it needs to be connected to certain parts of the board and then take readings from the scope as your adjusting the laser you cant do this without it as you can damage the new laser if you get it wrong.
Now you can fit the laser yourself thats the easy part but the scope costs about £1000 or $2000 so more than a new ps3.
If you can buy a working laser out of a damaged ps3 thats over heated then you should find it will work as sonn as you fit it in but new ones need calibrating.
Try this so you get some idea of the procedure with the scope use your search engine and type in:
how to calibrate ps3 laser
or
how to calibrate ps2 laser
this will then bring up loads of sites that show you how its done with the scope.
Its not worth doing it without the scope as you will damage the laser beyond repair but buy the new laser and get someone to fit it and calibrate it for you as that would be the cheapest sollution let me know if you need further assistance ok
Mar 14, 2008 | Sony Playstation 3 (PS3) Console
Thrustmaster Ferrari Gt F430 Wireless Cockpit For Ps3 Logo
Top Thrustmaster Video Game Consoles & Games Experts
James Wishart
Are you a Thrustmaster Video Game Console and Game Expert? Answer questions, earn points and help others
