Question about Fuji FinePix A345 Digital Camera
Just won't take pictures - Fuji FinePix A345 Digital Camera
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
How to capture best picture
That depends on what you're taking a picture of, and on what you want that picture to say to the viewer. The best procedure for taking a portrait won't be the best procedure for taking a landscape, for example. You probably won't want to take a picture of a grandfather the same way you'd take a picture of his granddaughter, either.
That's just the technical side. You also have full control of the artistic side. You decide on the camera position, the time of day, vertical or horizontal orientation, etc. Sometimes you can reposition the subject, sometimes you can't (buildings, trees, and mountains are a little difficult to move). You decide what's in the picture and what's not. You decide whether the picture should be bright or dark.
The camera is just a tool. You're the photographer.
May 02, 2012 | FUJIFILM FinePix XP20 / XP22 Digital...
My motorola triumph won't send pictures mms
Check your APN settings
http://www.virginmobile.co.za/support/support-category/general-services/gprs-settings-and-usage/gprs-and-mms-settings-for-android-phones/
different locations you go sometimes have dead spots so less signal wont send mms. you can also connect to your home/public wifi to send mms,
May 03, 2017 | Motorola Mobility Triumph
My 50 inch hitachi hd projection tv picture won't
This T.V. more than likely has a bad lamp. I don't know the model number so look up on ebay for a lamp replacement by model number after you inspect it and find it to look cloudy or exploded.
Jun 20, 2011 | Hitachi Televison & Video
42" television that won't display
You have the picture mode set ion 4:3 if its not the TV it will be any cable or satellite you have connected, you need 12:9
May 15, 2011 | LG Televison & Video
When transfering pictures from camera to PC EasyShare will not transfer some pictures. "picture already exists" in My Collection. These are all new pictures taken with blank memory card. This occurs even...
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
Dec 26, 2009 | Kodak EASYSHARE M1063 Digital Camera
We won an element 26in hdtv this weekend. we are
It could be a feature as some TV's have a zoom feature, widescreen setting, picture-in-a-picture, etc. Have you consulted the user manual?
Oct 19, 2009 | Televison & Video
Fuji FinePix A345 Digital Camera Logo
24 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
