Question about Garden
Broken frame under tank, can you buy this separately
Replacing broken torsion bar and how do you install it.
Ther is a bolt that adjusts the tension near the rear othe the bar, back it off , jack it up under the frame , not the a arm , put jack stand under frame , then jack under a arm , remove bottom shock bolt and ball jioint nut , separate , you may have to unhook sway barl link let arm down replace torsion Barr reassemble and adjust tension with adjustment bolt
Aug 08, 2016 | Cars & Trucks
Where'd position of the fuel filter of Sienna 2006
usually under the vehicle along the frame .
Jan 23, 2016 | Cars & Trucks
How do I find the fuel filter on a 2001 Plymouth neon.
you could ask a dealer or at the auto parts store where you would buy one . start looking from the gas tank and follow the lines till you get to the motor .many are bolted to the frame under the car
Aug 21, 2015 | Plymouth Cars & Trucks
1992 ford f250 rear tank removal to fix leak can
Yes, stop by the parts store and you can buy them there. BE PREPARED for fuel to come out, it is under pressure...Will be okay after released, just be ready. TAPE closed all lines to keep out dirt.
Jun 13, 2010 | 1992 Ford F250
Where is the fuel pump in a 86 lincoln town car located
inside the gas tank, and also onthe driver side frame rail under the car under the driver door hindge inside the frame rail with a plastic cover over it held on with a hose clamp and held to the frame with a self threading bolt that has a 13MM head. has a fuel line ( plastic ) comingout ofboth ends and a 2 wire electrical connector. The tank pump is in the front side of the tank and with the car jacked up by the body it's just above the rear axel and can be removed with the tank still mounted to the car.. The tank needs to be level and less than 1/2 full orr the fuel will come out as the tank is opened. some cars have only the tank pump, and none on the frame.
Jun 12, 2010 | 1986 Lincoln Town Car
WHEN SWITCHING TO FRONT TANK THE SWITCH SEEMS TO WORK BUT RUNS OUT OF GAS, IS THERE A VALVE THAT COULD POSSIBLY BE STUCK OR BROKEN? ALSO THE REAR TANK SEEMS TO BE FILLING INTO THE FRONT TANK
yes you will need to replace the switching valve, located under truck on driverside inside frame rail, also you may have a bad fuelpump, but you wont know until valve is changed.
Jan 07, 2010 | 1986 Ford F 250
Where do I find the fuel filter on a 1998 Ford Ranger XLT 2.9 liter?
If it's new enough it might be inside the fuel tank, if not then it is probably in between the fuel tank and the engine on the inside of the frame rail underneath the truck on the driver's side. It will be a small round inline filter. The special fittings on the ford are a pain so you may have to buy the tools for that from O'reilly's.
Sep 20, 2009 | 1988 Ford Ranger
Fuel filter?
HI. this seems to be a faulty(clogged) filter but, i would also change the fuel pump as well. this is good preventive maintenance. the fuel filter can be changed in the parking lot. it is located near the fuel tank and, it is along the outer frame work, inline with the fuel lines.
You will need to separate the fuel lines on each end of the filter to release it. there will be clips on the ends of the filter that hold the fuel lines. be careful not to break these clips. it is very hard to release the fuel lines of the filter when these clips are broken.
To clarify the location of the filter, it is located Under vehicle, driver side, below seating area, front of fuel tank, mounted on frame rail in fuel line
Jun 01, 2009 | 2000 Pontiac Montana
Grease in between glass on oven door
You have 2 pieces of glass that are separated by a frame then sealed. What has happened the seal has been broken and thus allowing air and grease inside. You can take it apart but the grease will come back, or you can buy a repalcement glass and be done with it. The question is, do you want to go to the trouble of cleaning the glass (1-2 hours of disassembly and assembly) probably once every 2 months depending on how often you use the oven, or buy a new one and it will always be clean. One caution, cleaning the glass periodically weakens and flexes the metal frame or band thus making it harder to properly seat the glass.
Feb 22, 2009 | Kenmore 47783 Electric Single Oven
Garden Logo
701 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
